Old 08-18-2016, 08:12 PM   #1
1973 31' Sovereign
Minneapolis , Minnesota
Painted Floors?
Has anyone painted the floors of their Airstream or other trailer? I am very seriously considering it. I'm *really* not worried about resale value. But I would like if there is advice anyone could give about this.
Thank you, love. maya
fairtheewell is offline   Reply With Quote
Old 08-18-2016, 08:23 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
I've seen a number of floors where the floor covering was removed and the subfloor painted or stained and urethaned. If the subfloor is in good shape and can be sealed this seems to be a reasonable solution.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 08-18-2016, 08:41 PM   #3
1973 31' Sovereign
Thank you Janet!
I believe this is the way forward. We had a painted kitchen floor (high traffic, 50 people with boots on everyday) and it held up well. The subfloor has two spots that are damaged but are being replaced this weekend (knock wood).
Old 08-18-2016, 08:50 PM   #4
1979 23' Safari
Wayland , New York
I painted mine when I replaced the floor to protect it, still haven't gotten to the point of putting something over it as I continue working on it. It still looks pretty decent if you don't notice wear from heavy work going on in it and some marks from sealant drippings. Seams and floor hold down screws are visible.
I used porch and floor paint from Home Depot,
I thought of using the epoxy floor covering you can use on garage floors that they also had. It would probably hold up better than just paint.
Old 08-18-2016, 09:14 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I see no problem with it....I have a garage with a plywood floor in it. I painted the floor with 2 coats of barn paint and 2 coats of poly. I drive vehicles in and out of it and have no wear. Water, oil, nor antifreeze have left a stain.
CRH is offline   Reply With Quote
Old 08-18-2016, 09:15 PM   #6
1973 31' Sovereign
Hmmmmmm.... Epoxy floor covering. That is interesting.
Old 08-18-2016, 09:18 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
I looked into the garage epoxy at Lowes and Sherwin Williams. None I saw was approved for wood
Old 08-18-2016, 09:54 PM   #8
1973 31' Sovereign
Now that is the kind of thing I wanna hear! Thank you so much!
Old 12-05-2016, 11:22 PM   #9
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
I am almost finished doing what you mentioned. Got tired of water leaks and soaked rugs. I removed all and stained the plywood. In the next few days I will put several coatings of floor poly on it.
Barbieri is offline   Reply With Quote
Old 12-16-2016, 12:09 AM   #10
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
Almost finished have to put in some trim. Click image for larger version
Name:	ImageUploadedByAirstream Forums1481868466.958143.jpg
ID:	276750Click image for larger version
Name:	ImageUploadedByAirstream Forums1481868489.767224.jpg
ID:	276751Click image for larger version
Name:	ImageUploadedByAirstream Forums1481868508.044460.jpg
ID:	276752Click image for larger version
Name:	ImageUploadedByAirstream Forums1481868544.100535.jpg
Old 12-16-2016, 06:39 PM   #11
1973 31' Sovereign
Thank you! The winter beat me to finishing the flooring but come spring I'll finish her up!
Old 12-16-2016, 06:48 PM   #12
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by Barbieri View Post
Wow, looks really good in the pics!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-16-2016, 11:27 PM   #13
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
When I put the oil stain down I did not wipe it. I let it soak in to blend with the water stains. I also used cpoe and sanded it. Then I used three coats of polyurethane floor varnish. It's not perfect but it's better than having soaked rugs rotting the floor. I didn't cover all openings. Some of them led to the belly tanks. Since I keep a dehumidifier on all the time I figured to leave them open. It would remove any condensation that accumulates below.
Old 09-26-2017, 12:43 PM   #14
Lily&Me's Avatar
Normal , Illinois
Wondering if you painted your floor, and how it turned out?
I have stains on my tiny floor space from moisture seeping under, and have been reading about painting it with porch and deck paint...it seems fairly foolproof and straightforward, and I have read of this down for years on floors such as a household laundry room and holding up well.
My flooring is completely intact, but the light colored "cork" flooring makes the stains very obvious.
Anyone else painted their vinyl/linoleum floor, rather than replace it?
Maggie
Lily&Me is online now   Reply With Quote
Aluminum floors? Janet H All Argosy Trailers 10 12-23-2009 08:54 PM
New Hardwood Floors 87 34' Excella tslanier Repairing/Replacing Floor &/or Frame 1 10-12-2006 09:11 PM
Bamboo floors M&J Siegford Floor Finishes 27 07-04-2005 07:29 AM
Argosy Minuet Floors overlander64 All Argosy Trailers 19 03-22-2004 09:57 AM
Airstream Floors Deny Floor Finishes 8 02-24-2004 09:12 AM
