Old 02-25-2008, 03:57 PM   #15
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
AHA! that's the kind of floor I've been looking for in my Safari, and IKEA to boot. just fits the vintage perfectly, easy to install, green, wow, you have made my day...so I'm sending you some karma...groove on..
fotochop is offline   Reply With Quote
Old 02-26-2008, 07:25 AM   #16
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Thanks, glad this was helpful.
Great website by the way!
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 02-26-2008, 07:35 AM   #17
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Great looking floor, and trailer, btw. Thanks for sharing!
Uwe
www.area63productions.com
Old 02-26-2008, 08:39 AM   #18
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Your floor looks very good!
How much expansion/contraction space is needed around the edges?
crispyboy is offline   Reply With Quote
Old 02-26-2008, 08:44 AM   #19
cameront120's Avatar
1972 25' Tradewind
As with any floating floor, you'll want a gap of about a 1/4" at the perimeter. Although, because this product has a plastic backing, rather than MDF, one might be able to get away with less.
North Vancouver, BC
Old 02-26-2008, 08:47 AM   #20
mandolindave's Avatar
Slightly bland
I could't find much of a selection available. Light beige, dark beige, medium beige, not so medium beige, and........beige
mandolindave is offline   Reply With Quote
Old 02-26-2008, 08:50 AM   #21
1972 25' Tradewind
On the Canadian website there is a blue, grey and black also available.
North Vancouver, BC
Old 02-26-2008, 08:51 AM   #22
1972 25' Tradewind
Personally, I would buy Marmoleum and glue it down to the subfloor as a single sheet, rather than go with tile.
North Vancouver, BC
Old 02-26-2008, 10:25 AM   #23
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
The instruction sheet states that 8mm is the spacing required, ew used the thickness of a tile which is around 1/4" I will tell you how that worked when the summer heat arrives here in AZ.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 02-26-2008, 10:28 AM   #24
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
The linoleum tiles come in black, beige. They have grey and blue in a plastic tile, which we checked out. The blue is very close to AS Blue. we were thinking of purchasing a box to make a mat outside the front door while we are camping. it can be easily dissasembled and stowed.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 09-27-2011, 09:28 AM   #25
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Update on this flooring, unfortunately it did not withstand the hot summer heat in Arizona while the trailer is in storage. The linoleum tiles de-laminated from the plastic tiles. They expand at different rates and did not hold up. The floor lasted about 3-years. We have replaced the floor with a good old solution VCT Glued directly to the subfloor, it looks vintage and very similar to the original tiles. We are very pleased with the outcome. Time will tell how it holds up in the heat. So far so good! This was the hottest summer on record in AZ and it held up very well.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 09-27-2011, 09:34 AM   #26
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Install question
I've purchased VCT and have not installed yet. Did you align the seams with the seams in subfloor? Mines gutted and am doing the entire floor. This summer for us has been cooler than normal, but the inside of my trailer see 115 regularly in the summer.
Mike
SilverHoot is offline   Reply With Quote
Old 09-27-2011, 09:41 AM   #27
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
We used a floor filler to fill in the gaps in the subfloor. Then we found the center point in the trailer and worked from there. I do not believe that we have any tile seams that aligned with the subfloor. We snapped a chalkline running the full length of the trailer and another intersecting one going across which gave us four corners to start the tiling process. It is the very same method you would use to tile a room in a house. It is a bit trickier to find the center of the trailer with all of the cabinetry in place but, we were able to do it.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 09-29-2011, 05:14 AM   #28
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Thanks for the update. I'm thinking about what kind of flooring to use in my Bambi II & am glad you got back to this thread! I'm not sure what VCT stands for.....? But your new floor looks nice too (so did the old one when you first put it in!) I guess I won't be throwing that in my cart at IKEA.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Has anyone tried this flooring? wannaroam Floor Finishes 164 10-18-2012 08:15 AM
need new flooring ? bigghpappa4 Floor Finishes 3 08-11-2006 10:41 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
Flooring Fun-Lovin Floor Finishes 8 09-09-2003 11:15 AM
