Old 11-20-2011, 06:48 PM   #1
1962 19' Globetrotter
Vancouver , British Columbia
New to flooring but making do ….question
hi guys
I've layed 3/4 inch plywood down so far. Next step is to find some commercial grade flooring as i'm putting in a retro "checker" style floor. Any ideas as to what type would be good?
I'm new to flooring and this is my first time doing it. Any input would be great….dont want to go heavy ceramic style….just want to know what options to look at.
thanks!
Stupidnoob!
Stupidnoob is offline   Reply With Quote
Old 11-20-2011, 06:58 PM   #2
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Look at vct. Armstrong has many colors to choose from.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 11-20-2011, 07:13 PM   #3
im actually just looking at it now haha
i need a strong commercial grade as i'm turning it into a concession trailer….will look at armstrong right now
thanks so much
Old 11-20-2011, 08:00 PM   #4
cameront120's Avatar
1972 25' Tradewind
Tarkett is also a manufacturer of Vinyl Composite Tile (they are the makers of Azrock, Johnsonite and Expressions flooring). It is used extensively in commercial and institutional applications. If you desire a natural product, linoleum by Marmoleum is an option.
North Vancouver, BC
Old 11-20-2011, 08:50 PM   #5
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
You may also want to look at a sheet product if it going in a concession trailer. Fewer joints and seams may make cleanups a little easier. Armstrong also makes that product. Look also at marmoleum.
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 11-20-2011, 09:05 PM   #6
Central , Mississippi
Originally Posted by Stupidnoob View Post
hi guys
I've layed 3/4 inch plywood down so far. ...
thanks!
Stupidnoob!
need to ask... 'layed down'...means over the old floor?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-21-2011, 01:02 PM   #7
no the p.o. installed a new subfloor right before i bought it
it got a little bit damp in the rear but hopefully i can dry it out. shouldnt be an issue
Old 11-21-2011, 01:33 PM   #8
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
I laid 6" x 36" vinyl planks and it has been the one renovation item I regret. The seams have been an issue.
I don't know if its because I put it down in November (colder month), didn't use enough glue or its just not the right product for the application. The seams shrink when its cold leaving an 1/8" gap and swell in the heat pushing them up against each other.
If given another opportunity, I would choose a product that comes in large sheets.
Good Luck!
star kitty is offline   Reply With Quote
Laminate Flooring: which is best? perryg114 Floor Finishes 62 12-04-2012 07:30 AM
Laminate flooring: when to install? Phrunes Repairing/Replacing Floor &/or Frame 2 06-07-2011 05:52 AM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
Bamboo Flooring Argosy22 Interior Restoration Forum 1 01-23-2011 08:41 PM
