Old 06-12-2016, 09:44 AM   #1
1994 34' Excella
Warren , Manitoba
New Luxury Vinyl Flooring-What Baseboard??
I just installed Mannington click together vinyl flooring and left the suggested space for expansion. What to use for baseboard to cover the gap??? The walls in our 1994 have the "carpet" on them. What have others used, and how did you attach the moulding. Floor looks great, and on street side the carpet covers the gap quite well, but on the entry door side the wall carpet is up about 3/4" and the gap is very visible. Any thoughts or ideas?? Thankk you! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 06-25-2016, 05:48 AM   #2
2003 25' Safari
London , Ontario
HI : I recently replace the carpet in our AS with a vinyl "click" flooring in a dark wood in design. When I came to the street side I covered up the wall covering that was tacked to the floor and cut the new flooring tight to the vertical wall.... Not a perfect solution but that side of the AS has a couch arm, fold up table and a dinette so the lack of moulding was minimized. Not a perfect solution but the floor looks good.... Trusting this helps...
JOZRVHLR is offline   Reply With Quote
Old 07-18-2016, 04:49 PM   #3
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I can't offer anything relative to your question (sorry). But I am curious which of the Mannington click flooring did you use? Are you happy with it?
Thanks!
Old 08-23-2016, 02:28 PM   #4
1967 24' Tradewind
Bishop , Georgia
Baseboard trouble also.
Also just put down Luxury Vinyl Planking by Stainmaster ( from Lowes). Easy to use and shape. But... can figure on the baseboard. Especially in the original bathroom area. Working on a '67 Tradewinds.
TomSenyitko is offline   Reply With Quote
Old 08-31-2016, 01:40 PM   #5
1967 24' Tradewind
Bishop , Georgia
'67 Tradewinds new vinyl planking and moulding
As we have found out, once you put down the planking, there is going to be space that needs to be filled. I couldn't find anything else to finish the job so.... rope lighting is the answer ( stop laughing). Still open to suggestions.
Flexible baseboard molding larry b Floor Finishes 3 12-31-2014 05:31 PM
Baseboard jornvango Interior Restoration Forum 3 10-04-2013 07:32 PM
Baseboard heaters Forger Furnaces, Heaters, Fireplaces & Air Conditioning 6 04-20-2011 07:51 PM
new vinyl over vinyl cabinets? Aage Cabinets, Counter Tops & Furnishings 28 09-29-2009 07:50 AM
New Classic 31' - hate vinyl flooring/carpet! jmd5602 Floor Finishes 22 04-05-2008 06:17 PM
