Old 08-13-2016, 08:38 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
New Floor At Last Continued!
Here are some pictures of the finished product.
ID:	269005   Click image for larger version
ID:	269007   Click image for larger version
Hans627 is online now   Reply With Quote
Old 08-14-2016, 06:29 AM   #2
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
That looks very nice. ☺
I'm starting to shop for my floor covering now.
What is the flooring? Glue down or floating? Are you able to install it yourself?
Thank you!
Dingo Girl is offline   Reply With Quote
Old 08-14-2016, 07:09 AM   #3
Hans627's Avatar
Thank you!
Thanks for the complement!
Yes I did it myself. Fortunately I have a workshop with equipment to cut and fit the various pieces. I did not remove all interior cabinets which meant that cutting accuracy was more critical.
I used an Armstrong Luxe Plank product ( http://www.armstrong.com/flooring/lu...luxe-plank.asp) with FasTak. It has a sticky backing which adheres to the floor but can be peeled up again. So it is not "floating" nor is it glued down. We will see how it performs in the long run. It was recommended by the guy at the flooring store. Of course there are many products that could be used.
If you have any questions I would be pleased to try to help!
Old 08-15-2016, 05:27 AM   #4
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thank you!
Old 08-20-2017, 02:14 PM   #5
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
so now that the floor in airstream is a year old how has it held up? any separation like some many other have experienced?
how has the surface handled trailer life.
thanks
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 08-21-2017, 04:46 AM   #6
Hans627's Avatar
thanks
It has held up very well to "trailer life". No signs of any wear at all and it is easy to clean.
Regrading the separation issue; when it is cold, about 50 degrees and lower, there is some separation. But when it warms up again the separation goes away. So there is definite contraction due to temperature fluctuations. Since most of our camping is in warmer weather it has not been a problem. I tend to be a perfectionist (which on projects like this is not an asset) so I would look for a different product, only from the expansion/contraction issue, if I were to do it again. My DW says I'm crazy (not the first time) and the floor is perfectly fine!
New Floor At Last! Hans627 Floor Finishes 0 08-13-2016 08:34 PM
At Last - At Last pt1949 General Interior Topics 9 02-03-2014 10:40 PM
'74 Trade Wind..broken water line, continued Ameliasdad Fresh Water Systems 1 04-07-2011 01:10 PM
Need advice continued ........ hapitauk Member Introductions 2 12-03-2006 10:53 PM
Undeterred we continued driving South.... Guitars Our Community 7 12-14-2003 05:23 PM
