I would question the stick down tiles with the temperatures swings you will have up north. That would be easier but may not last a long without lifting around the edges.
Consider removing the cabinets, not the kitchen sink cabinet, and putting down laminate. Removing the cabinets is easy and gives you a good area to work in and greatly reduces the cutting. I used Armstrong product mainly because of the color match and the locking system they use. So laminates would be hard to lock in place in a small area.
2004 Excursion 4x4
