Newbie here> Is there anyone out there at this time that can express to me when I go to replace my floor on my unit which way i should run the flooring. I have heard that either way is fine. Is this correct? Also can I lay a tile floor in the bathroom and hallway?
If using plywood, I would run it crosswise. Plywood is about twice as stong lengthwise (across the frame) as it is across the short dimension. If you use something other than plywood you should call it out.
I would reconsider the tile. The weight is a major issue. That goes for anything you add to your Airstream. Do some searches on this forum and you will find a wealth of information about weight limits.
That said, I've seen others who have used tile in their Airstreams...
Other then plywood, sup floor that is. I am using bambo can you give me an idea wiether i sould lay lenght of trailer or width of trailer. and float the floor also?
You can lay it either way because it's purely decorative. IMO it’s more aesthetically pleasing to lay it lengthwise, but it will be easier to lay and make your cuts if you lay it across the width of the trailer.
Across the trail also makes it look wider. Thats how I did mine. And I also didn't do it all at once so it makes it easier to start and stop..
Jason
Airdaddy Here> All of you have been helpfull and I give thanks all... however today I was at Lowes my favorate place to shop. I have decided not to use the Bambo I have and go with something else. Can anyone give some more helpfull hints to wood floor options?
The Allure Trafficmaster is a consideration, and there is a similar product at Lowes called "Novalis" plank vinyl flooring. The biggest difference between the two is the Trafficmaster sticks to other Trafficmaster planks along the edges, and floats, while the Novalis is peel 'n' stick (which sounds scary, but people have used peel 'n' stick in Airstreams with success).
I would definitely advise against real tile in the bathroom. Not only is it heavy, but with the way the trailer flexes and moves, I don't see any way to avoid the grout cracking, and possibly the tile itself cracking as well. Vinyl tiles, linoleum tiles, sheet vinyl, or sheet linoleum are common products used in Airstream bathrooms.
