12-27-2009, 04:04 PM
mineral
, Virginia
Need Floor Covering Suggestions
I am getting ready to put in a new floor covering in my 76 Trade-wind, and would like some suggestions. Thanks!
12-27-2009, 05:59 PM
1995 25' Excella
waynesboro
, Virginia
I have done two flooring projects in 30+ y/0 AS and was most pleased with the last, using an "Engineered" flooring product....light weight, easily installed nice look when the job was finished....
12-27-2009, 06:32 PM
mineral
, Virginia
Thanks for your idea. That is what I was hoping would be a good choice. That means no glues, and no nails, right? Thanks!
12-27-2009, 10:10 PM
1963 16' Bambi
1962 22' Safari
Yreka
Hello,
We looked at all sorts of options, lots of folks choose cork flooring, very comfy. However, we often camp in dirt prone areas... so we went simple vinyl. Wash and wear is good. I have throw rugs that fit nicely and can be thrown in the washer quickly so if it is raining and muddy, no worries.
Largely your choice will depend on how you use your trailer, your personal preferences for how it looks and your pocketbook.
Good luck finding just what you want!
12-28-2009, 03:31 AM
1982 24' Airstream 240
Ventura
We love our cork click flooring.
We put some throw rugs down to protect the cork but they are easy to pick up and shake....floor easy to sweep.....it is not cold and is easy on the feet...It is fastened at the edges....came in rectangular pieces..highly recommend it. paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
12-28-2009, 04:50 AM
mineral
, Virginia
Thanks for all the replies! If I were to use the engineered flooring, are there special recommendations that you prefer over others. Also, as for the cork flooring, that is new to me. Where can I get that? Sounds interesting! Also, If I use engineered flooring, should I wait til the floorplan is laid out, and then install the flooring to allow for expansion and contraction, or is it ok to start with a new flooring, and build up on top of that?
12-28-2009, 05:49 AM
1973 25' Tradewind
Chatham
, Ontario
If you build on top of engineered flooring, you need to drill a hole out with a hole saw where you are going to fasten whatever you put on top. The hole will allow for the floor to move (expansion). Otherwise you will be fastening the floor down which could lead to problems.
I have been looking at a fairly new flooring (to me) that is like vinyl, but is made with fiberglass. it is thicker than vinyl and more pliable. Much like the old linoleum. It doesn't need to be glued down, which is a plus if you ever get moisture. Just roll it up, clean and/or dry and then roll back down.
12-28-2009, 05:53 AM
1968 24' Tradewind
Oxford,
, Mississippi
We liked the look of cork and the durability of sheet vinyl. Since I had the trailer gutted we went with a heavy duty sheet vinyl in a cork pattern. Got the best of both. Also, I wanted a solid floor covering especially in the rear as it is hard to keep my rear access hatch from leaking a little.
12-28-2009, 06:05 AM
1965 22' Safari
Vassar
, Michigan
Floor Covering
We installed new capet (birber) and use a mat and shoes stay at the door.
We do have to be very careful but find the comfort of carpet worth the extra effort.
01-03-2010, 03:26 PM
1988 29' Excella
Collinsville
We just ordered Allure Trafficmaster from Home Depot. We bought the cork pattern.
01-03-2010, 03:44 PM
mineral
, Virginia
Good deal! Thanks for the ideas! Can hardly wait to get started on the project. Keep comments coming!!
01-03-2010, 04:01 PM
1969 23' Safari
New Orleans
, Louisiana
VCT tiles
I used "VCT" tile (glued in) which I believe is recycled vinyl. They are quite hard, used in hospitals, schools, industry. You can wax them to a really high gloss shine or leave them matte finish. They are also very affordable ($100 for a 23' Safari) and last practically forever and come in a WIDE variety of colors. Not everyone digs the semi-industrial look, but its just my cup of tea.
01-12-2010, 04:41 PM
Silver Bullet
1986 34.5' Airstream 345
choctaw
, Oklahoma
I used the laminate plank flooring from home Depot. It's been good till we got here in New Orleans. It's COLD!!! here. I put an electric space heater on it and the heat curls the seams up. When I get home I got to change the floor cover out. Rats!
mel
01-12-2010, 05:02 PM
1965 17' Caravel
Panama City Beach
My newly acquired 1963 Trade Wind just got new 3/8 inch hardwood floors. Not laminates. Golden Oak color on Teak wood. I glued and nailed so they are there for good. GORGEOUS..
01-13-2010, 11:13 AM
Silver Bullet
choctaw
, Oklahoma
I may use bamboo. I put it in my (house) living room. It's holding up well. Don't want to nail it in the motor home. Sure wouldn't want to nail though the medal under the sub-floor. and not sure about gluing it either. That's why I used the laminate plank. It (plank) just don't take the extreme temperature swings.
01-13-2010, 11:58 AM
1992 29' Excella
JOY IN
Hi Mrhany, look at my thread on my cork floor, very easy to install, use a water base adhesive you will love it or click on my profile pics there. by the way laments are very high in flammability, cork is not. go to i-floors .com
01-25-2010, 11:54 AM
1974 Argosy 26
Morrill
, Nebraska
OH how the temperature changes.
I have decided to go with indoor/outdoor carpet. Found some nice sruff at Home Depot. My concern with vinyl or engineered flooring is with the shrinkage. Our temperature varies here from -40 to +105 F. From everything I've read, the shrinkage would be significant with either material. The carpet will cost $155.00 for our 26' Argosy. I figure I can replace it after 5 years if necessary.
01-27-2010, 04:34 PM
Silver Bullet
choctaw
, Oklahoma
I just hate the sand burs/goat heads we get in carpet. They are the native grass around here.
mel
01-27-2010, 04:57 PM
1965 28' Ambassador
Irving
Check out the new Fiber Carbon series at amtico.com really cool squares with fiber in the squares.
01-27-2010, 05:14 PM
2000 34' Limited S/O
Greensboro
, North Carolina
I had Pergo in my last Airstream and recently traded it for a 2000 34' Limited Sofa SO with carpet. The first thing I did in our renovation process was have the carpet taken out and Pergo "Hardwood" flooring put it. It looks great, is very durable and easy to maintain. We purchased smaller Persian rugs to put over the Pergo in some areas to make it more comfortable and softer.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
