Old 01-13-2010, 11:13 AM   #15
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I may use bamboo. I put it in my (house) living room. It's holding up well. Don't want to nail it in the motor home. Sure wouldn't want to nail though the medal under the sub-floor. and not sure about gluing it either. That's why I used the laminate plank. It (plank) just don't take the extreme temperature swings.
choctawmel is offline   Reply With Quote
Old 01-13-2010, 11:58 AM   #16
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
Hi Mrhany, look at my thread on my cork floor, very easy to install, use a water base adhesive you will love it or click on my profile pics there. by the way laments are very high in flammability, cork is not. go to i-floors .com
Originally Posted by Mrhany View Post
I am getting ready to put in a new floor covering in my 76 Trade-wind, and would like some suggestions. Thanks!
wbcci ,#3510 NEU & 4cu http://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 01-25-2010, 11:54 AM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
OH how the temperature changes.
I have decided to go with indoor/outdoor carpet. Found some nice sruff at Home Depot. My concern with vinyl or engineered flooring is with the shrinkage. Our temperature varies here from -40 to +105 F. From everything I've read, the shrinkage would be significant with either material. The carpet will cost $155.00 for our 26' Argosy. I figure I can replace it after 5 years if necessary.
Old 01-27-2010, 04:34 PM   #18
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
I just hate the sand burs/goat heads we get in carpet. They are the native grass around here.
mel
Old 01-27-2010, 04:57 PM   #19
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Check out the new Fiber Carbon series at amtico.com really cool squares with fiber in the squares.
bwaysteve is offline   Reply With Quote
Old 01-27-2010, 05:14 PM   #20
2000 34' Limited S/O
Jamestown , North Carolina
I had Pergo in my last Airstream and recently traded it for a 2000 34' Limited Sofa SO with carpet. The first thing I did in our renovation process was have the carpet taken out and Pergo "Hardwood" flooring put it. It looks great, is very durable and easy to maintain. We purchased smaller Persian rugs to put over the Pergo in some areas to make it more comfortable and softer.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 01-27-2010, 06:20 PM   #21
1976 25' Tradewind
1959 22' Flying Cloud
Mineral , Virginia
3/8 in. Flooring Option
Did you build onto this flooring, or around the cabinets, etc.? Also, where did you purchase the 3/8" flooring? Thanks!
Mrhany is offline   Reply With Quote
Old 01-27-2010, 06:45 PM   #22
I had it done at my local Airstream dealer, Out of Doors Mart. They removed the cabinets and then put down the flooring. Purchased the Pergo at Lowes Hardware.
WBCCI #4358
Old 01-27-2010, 07:00 PM   #23
oh2bcarefree's Avatar
House Springs , Missouri
Images: 48
Fiber Carbon
That flooring is awesome... I am guessing one has to have a BIG budget or win the lottery? We are planning to go with Marmoleum sheet as we are doing from the floor up, but this stuff is way cooler. Man - I'm going to have to start playing the lottery now.
Tina
oh2bcarefree is offline   Reply With Quote
Old 01-27-2010, 07:12 PM   #24
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
PO put in ceramic tile, as good as it looks and cleans, I would look at the cork, vinyl tiles or definitely the new engineered woods, some can even be refinished with care to extend their life. Most cg have lots of sand and we are always sweeping, so any finish would need to take that into account.
Old 01-27-2010, 09:34 PM   #25
Maniacal Engineer
barts's Avatar
Menlo Park , California
Keep in mind that whatever your floor covering, being able to spot leaks (that rot floors...) is important. When we pulled up the carpet on our 1971 Tradewind, several (thankfully small) areas of rot were immediately apparent. We're going to go the epoxy route for repair & protection and then paint the floor. I'm lobbying for aluminum filled moisture-cured polyurethane, but saner heads may prevail.... We'll then use rugs to add the desired comfort/looks. Later on we may shift to a more decorative flooring, but as our trailer will get used for camping in unimproved areas (such as Burning Man and our land in the San Juans), this may be the best approach for us as it's hard, damage resistant and readily spot-repaired, unlike some other approaches.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 01-28-2010, 04:50 AM   #26
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
mice love carpeted trailers, especially the carpet foam.underneath.
Old 01-28-2010, 05:53 AM   #27
1965 17' Caravel
Panama City Beach , Florida
3/8 hardwood
I used 3/8 inch hardwoods from Floor Decor. Cut it in around the cabinets then used shoe mold to finish the edges. Looks fabulous..
TANK FAMILY is offline   Reply With Quote
Old 02-06-2010, 02:59 PM   #28
Edinboro , Pennsylvania
Did you use a vapor barrier under your Pergo?
wa3pjl is offline   Reply With Quote
Covering your Airstream wazzup Winterizing, Storage, Carports & Covers 55 09-22-2011 10:16 AM
Looking For Floor Trim Suggestions DEITZ645 1987 - 1989 Excella 7 02-13-2008 09:25 AM
Covering the AS chaimemet Winterizing, Storage, Carports & Covers 1 11-27-2007 05:19 PM
covering mikee Winterizing, Storage, Carports & Covers 4 02-25-2007 09:24 PM
New floor covering krazeekalvin Floor Finishes 11 02-24-2007 06:49 PM
