Old 04-01-2011, 07:21 PM   #1
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Need design/color advice for tile
I have two colors of commercial vinyl tile, red and green.
I probably have enough red to do the whole floor, but only have one more box of green.
The 2x4s are approx. where walls will be.
This is a first attempt at a layout. I have no idea whether it looks bad or not. Opinions? Advice?
ID:	125895   Click image for larger version
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 04-01-2011, 07:33 PM   #2
cameront120's Avatar
1972 25' Tradewind
I'd suggest that you try to create a central 'field' in one colour centred on the aisle. Then surround that field with the other colour. So think a long rectangle of, say green, down the aisle with a border or red for the remainder. What I see in your pictures doesn't really follow any rhyme or reason, design-wise.
North Vancouver, BC
Old 04-01-2011, 07:46 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
If it were me I'd do the whole thing one color...less busy that way. Even if I had to buy enough tile. It would be worth it because then I would have want I want, not what I have on hand. But that's me.
TB & Greg and Abbey Schnauzer
#3954
Old 04-01-2011, 08:01 PM   #4
DanielB's Avatar
This def. looks better.
I could do all red or I have enough green to run the stripe all the way to the ends of the trailer, or do the entire middle area in green and the ends in red,
or, get more green and do all green, or something else?
ID:	125902   Click image for larger version
- Andrew Carnegie
Old 04-01-2011, 08:17 PM   #5
1972 25' Tradewind
I would do the green as you have it, but end it before it hits the rear bathroom. That is, have the green rectangle centred on the visible living space. Do the bathroom in solid red. Another option would be one solid colour, or a red and green checker board pattern. How do these two colours fit the rest of your colour scheme?
North Vancouver, BC
Old 04-01-2011, 08:17 PM   #6
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Hey Daniel,
Interesting color choice. I know you got it pretty cheap right? I'd try to go with one color or the other so that people don't think that you are one of the people that celebrate Christmas year around. I'd have figured that you'd go with Navy blue or haze gray.
Lance
Top is offline   Reply With Quote
Old 04-01-2011, 08:41 PM   #7
DanielB's Avatar
I'll try out the checkerboard tomorrow and see how that looks.
Obviously *some* people don't like my choice of colors.
Yes, I did get them at a bargain, but there were a lot of colors to choose from, and I chose these. Green is my favorite color and dark red is second.
I got a couple boxes of green because I thought that all red might be too dark and the red because I thought all green might be too light.
- Andrew Carnegie
Old 04-01-2011, 11:40 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Try to envision how much of the actual floor will be visible once you get the furniture back in place...if you have a nice pattern figured out wihtout furniture it may look very different once everything else is in... I think Cameron's suggestion to do the bath solid is a good one...
#3954
Old 04-02-2011, 07:04 AM   #9
x
XXXX , XXXX
Daniel are you doing a different floor plan? Most of the red by the wheels will be under cabinets. Roadside there is the fridge cabinet, the pantry, a bulkhead wall and then the wardrobe cabinet in the hall right back to the bulkhead wall between the hallway and the rear bedroom . Curbside there is the kitchen counter with stove and sink, then a bulkhead wall, the shower, the bathroom sink and the toilet before the next bulkhead wall between the bathroom and the bedroom.
From what I can see some of the bathroom will be green and some red.
The same for up front. Take back a few rows of the green and replace with red. Start the green at the rearward edge of the entry door frame that way the living room and kitchen will be defined clearly by the two colors.
wasagachris is offline   Reply With Quote
Old 04-02-2011, 09:11 AM   #10
1972 25' Tradewind
This is why I was trying to suggest the green field of colour be centred on the actual visible space. Think of what will be a long hallway with a border of red and field of green in the centre. It'll only work if the cabinets, beds, etc, are all factored into the equation. If one goes with a checkerboard pattern, then none of that really matters. Although, the checkerboard should be properly centred on the finished space, otherwise it'll look wonky (actual Architectural term).
North Vancouver, BC
Old 04-02-2011, 09:41 AM   #11
lcurrie's Avatar
2005 19' Safari
Personally, I prefer the red. It's hard to beat an Airstream with red accents on the interior.
Lynn
Lynn
Austin, Texas
2005 19' Safari, Toyota Tundra
2 Small and Spoiled Dogs
lcurrie is offline   Reply With Quote
Old 04-02-2011, 11:13 AM   #12
DanielB's Avatar
Yeah Chris, not going with the original floor plan. These wouldn't be the exact place of the tiles. Just trying to get an idea of what would look ok.
That was kind of the original idea was to have the front area red, then the kitchen and hallway and bathroom green and the bedroom red with the green areas having a red border.
Def. don't want "wonky".
- Andrew Carnegie
Old 04-02-2011, 08:48 PM   #13
DanielB's Avatar
Tried out some different things here.
First diagonal pattern with a green bathroom.
Second, red with a green bathroom.
Next, all red.
Next, half red, half green
Next all green.
What looks best, or worst, or any other ideas?
Another thing could be red with green half tiles around the edges or green with red half tiles around the edges.
ID:	126008   Click image for larger version
ID:	126010   Click image for larger version
ID:	126012   Click image for larger version
- Andrew Carnegie
Old 04-02-2011, 09:02 PM   #14
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
I like the diagonal.
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
