Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 04-12-2009, 08:16 AM   #1
Profile:  1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Need advice on my Floor?
Hello folks well I have pretty much gutted my trailer took bath out and removed everything up front rite down to the wood floor. My question is I do not want to replace floor I do Not have time or money SO I was thinking of putting subfloor over it any Ideas?
Pictures:
Rear floor rot
Front floor under univolt is soft about 2 feet back
Before I remove rotted spot
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 04-12-2009, 08:40 AM   #2
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Sorry, I can't see your pics for some reason. Can you just replace the section thats failing? You can use floor repair screws to secure the floor from the top. It will take money and time to put down a sub-floor and you will still have a soft spot.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-12-2009, 08:42 AM   #3
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Putting a floor over the floor does not solve the problem and is a set up for problems later when you will have to pull everything out again and will have bigger problems. Your photos did not come through but there is a workable fix for small areas of floor short of replacing the entire floor. This approach is less acceptable for large areas which involve the C channel and where the floor is bolted to the frame.
1. Cut out the rotten sections
2. Treat old floor edges with penetrating epoxy resin
3. Screw/glue plywood support under existing floor so that you have a lip which extends at least 4" into the hole and 4" under the good section of original floor
4.Screw/ glue patch piece of plywood
Pay no attention to the man behind the curtain- WoZ
Old 04-12-2009, 08:46 AM   #4
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
You would be sorry
Almost all the work is done. You can replace sections of bad floor....looks like most is gone no anyway. Clean up the area, square up the portion to be removed, cut a replacement piece and install it. Many posts on the process with pictures are here. Some real good info is floating in Blog outerspace....essentially lost. If you cover the problem......?
Old 04-12-2009, 09:55 AM   #5
Profile:  1964 22' Safari
enosburg , Vermont
Could'nt open your pics. Adding thickness to you floor will cause some problems when you reinstall your interior and extra weight. You can probably work around that. The primary issue is the condition of the perimeter of the plywood, under the c-chanel 1-2 inches in from the outside edge. Shell bolts to plywood, plywood bolts to frame. If the belly pan and int skins are attached you can't be shure. You can go around the interior paremeter trying the wood with a screw driver, if theres' weak areas that means structural support problems, especially on a 31 ft'er. You're right, replacing the floor is a lot of time and money. Hope you can dodge the bullet, good luck.
putback is offline   Reply With Quote
Old 04-13-2009, 03:52 PM   #6
Images: 33
Pictures:
Rear floor rot
Sorry about pics I linked them to my gallery oh well pics are there just can't link them i guese
K/N Cool intake air
Duel power exhaust
Just looking in DE - need advice ltdontcare Member Introductions 1 01-28-2009 12:07 PM
Advice on new A/S. cmreumund On The Road... 12 10-29-2008 10:20 PM
Newbie needs advice on fixing rotten floor Lyvettely Repairing/Replacing Floor &/or Frame 5 02-02-2008 01:30 PM
Advice please! Bambi's Dad Member Introductions 26 04-13-2007 09:11 PM
Warranty Floor Replacement Advice gklott Repairing/Replacing Floor &/or Frame 1 06-24-2004 10:19 PM
