Old 06-04-2010, 08:31 PM   #1
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
nail down tongue and groove or floating? cork...
We want to install cork flooring as we refresh our '78 Minuet, but we have not found the product we thought we were looking for. I anticipated finding floating cork at Lowe's or HD, but have only found cork tongue and groove which must be nailed down. It looks like a great floor, but is this possible or good to do on an Argosy floor? Is the plywood underlayment thick enough to nail into? Is nail down okay for an rv floor? Where do you find plank cork floating floor? Which type is preferable. We'll also be going into the small bath area with whatever flooring we choose, so any pointers about that are appreciated. We'll be fitting around the trailer furnishings, so again, tips are appreciated. feel lost in the woods and need help! ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 06-04-2010, 09:19 PM   #2
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
After doing a good bit of research, we're going with cork. Rather than a floating floor, we're doing cork tiles. I'm not an expert on Argosy floors, but our Overlander has a 5/8" subfloor with a 1/4" plywood sheathing over (and overlapping) the subfloor to provide a smooth surface. I can't speak for others, but I'd be nervous putting nails in the floor. The floating floors are available online and I think you can special order a number of different options from your local big box hardware store. Some of the floating floors are the "click lock" which don't require fasteners. I'd be nervous about the cork in the bathroom, but again, your mileage may vary.
hampstead38 is offline   Reply With Quote
Old 06-04-2010, 10:58 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Georgia!
Your Minuet may be a special case particularly if it is the 6.0 Metre. Most 6.0 Metre Minuets produced in 1978 had aluminum composite flooring that won't accept nails (some of the 6.7 Metre Minuets also had the aluminum composite, but not nearly as high a percentage). If you Minuet has the composite aluminum floors, you are basically limited to floating floor products or carpeting. Another consideration is the weight of the product installed as the single axle Minuets had axles rated for no more than the GVWR of the coach.
Lumber Liquidators carry Lisbon "click" Flooring in several Cork styles.
Jelinek Cork also offers a variety of cork floating floors.
Good luck with your Minuet!
Kevin
Kevin D. Allen
AIR #827
No tongue and groove for floor bwaysteve Repairing/Replacing Floor &/or Frame 14 01-04-2010 03:24 PM
Nail in water line: Need to cut out floor & patch AirHeadsRus Repairing/Replacing Floor &/or Frame 12 07-17-2009 05:56 PM
Fix Scrathes with Nail Polish ? JDL Clearcoat, Exterior Paint & Trim 2 04-20-2009 07:35 AM
Cork Floating Floor ClassicRides Repairing/Replacing Floor &/or Frame 21 12-01-2005 08:12 PM
Finally Got My Groove On... Gwen Off Topic Forum 5 07-19-2004 09:45 AM
