Old 07-10-2007, 09:22 AM   #1
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
My new floor
Here is the new floor, I did this in about an hour and a half from goucho thru to galley. I will do the hall this afternoon. Very easy once I got the hang of it and purchased a pull bar. I wasted a box of laminate in the learning curve. Had to quit polishing for now as it is tooo hot for me.
James
ID:	40948   Click image for larger version
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 07-10-2007, 09:25 AM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
An hour and a half? Mercy! you are way faster than me. Thats a nice looking floor. I put pergo in this spring and I love it, I bet you are going to love that floor too.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 07-10-2007, 09:54 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
James,
Very nice. You will love it. It is counter intuitive to the community, but solid floors and throw rugs are really comfortable and you can keep them clean! In all five of the trailers I've started to remodel, the wall to wall carpet was the worst, icky-est item and there was invariably 1/4" of sand underneath.
If you want cool, come on up to Palmer Lake. I've got plenty of Airstream work to do and I'd even carry your lemonade or, if acceptable, beer! Today is very coastal-like--misty and 65 degrees. Yesterday wasn't too bad, got all the way up to 78. Nights are in the high 50s. How do ya'll sleep down in Texas?
Zep
Old 07-10-2007, 10:16 AM   #4
1970 27' Overlander
Houston , Texas
With the windows open, its a cool 80 degrees at night
James
____________
1970 Overlander
Old 07-10-2007, 06:01 PM   #5
1970 27' Overlander
Houston , Texas
Material Used
As requested by member:
I used glueless laminate flooring by TrafficMaster, Hamilton Oak. Available at Home Depot for $32 a carton, used 4 1/2, but one was used in learning curve. Also one roll of underlay moisture barrier for $25.
James
____________
1970 Overlander
Old 07-10-2007, 06:27 PM   #6
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Great job James. It sure remakes the trailer. We find similar flooring in our rig extremely easy to maintain and it always looks good. I must admit it took me a bit longer than it took you, but in my defense I had to stop multiple times for "pop" breaks as it was in the mid 90's when I did it a few years back.
Glad to know you've quit polishing for a bit. I'm feeling very guilty that I've not yet done mine.
Barry
safari57 is offline   Reply With Quote
Old 07-14-2007, 08:24 PM   #7
1976 25' Tradewind
Edmonton , Alberta
Hi jsflint,
I'm currently renovating my 1976 Airstream TradeWind and am contemplating using laminate flooring. Did you glue yours down or is it truly "floating" as is the case in a home installation? As well, did you apply the moisture barrier and underlay before installing it? I admire the dedication and hard work you put into polishing your Airstream. What do you use to make it so shiny?
Paul
pcaines is offline   Reply With Quote
Old 07-14-2007, 08:42 PM   #8
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
The floor looks really nice, so does the polishing job.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-14-2007, 09:13 PM   #9
1970 27' Overlander
Houston , Texas
Thanks for the encouragement
The pictures are a little deceiving. I have only polished about 1/3 of the trailer. The rest looks shiny just from removing the clearcoat. I am using Nuvite F7 grade for the 1st pass then will follow with finer grades for the next two passes.
The floor is free floating no glue used. Idid lay down a moisture barrier first. Its very solid with no slipage or creaking. I am not much of a carpenter either and there was about a four hour learning curve with one bundle wasted but once I got going in went pretty fast. I said it took an hour and a half but that is not the complete job, it ended in the galley. I have four boards needed to finish hall to bath but have to buy another bundle. There are several bad cuts but the quarter round should hide a lot.
It really make the trailer look and feel a lot more roomy too. I am very pleased so far.
I have many projects working at once and I just skip around when I get frustrated with one.
James
____________
1970 Overlander
Old 08-24-2007, 01:26 PM   #10
Lenore , Idaho
Images: 51
Looks great! Only thing I would have done different is had the pieces running lengthwise from one end of the trailer to the other.
heybaby1 is offline   Reply With Quote
Old 08-24-2007, 01:58 PM   #11
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
What is the brand/specs on the flooring?
BTW - looks very nice - GOOD JOB!
crispyboy is offline   Reply With Quote
Old 08-24-2007, 02:32 PM   #12
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Your new floor and trailer polishing look great. I want that floor What did you do at the bathroom door? I think our bathroom is plastic "tile".
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 08-24-2007, 02:45 PM   #13
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Very nice!!! How rigid is this flooring. Does it have any "bend" at all. Reason why I ask is that in my trailer, I have a seam in the kitchen between the two floor boards that have a slight crest to them. Just want to make sure that any planking I put in doesn't crack over this imperfection.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-24-2007, 04:17 PM   #14
I love Airstreams...
leefields's Avatar
1989 29' Land Yacht
Haines City , Florida
Talking looks nice......
i remember a post almost a year ago that dealt with laying the laminate length or width.....are you happy with going side to side....or do you think going front to back would have worked out better....
to me side to side looks great....and will likely be my choice on my squarestream after we get the walls and ceilings put back in.....
1953 Spartan Mansion
Ram 3500 DRW LB SuperCrew
PCS Professional Coach
AIR# 6366
leefields is offline   Reply With Quote
Old 08-29-2007, 05:12 PM   #15
1970 27' Overlander
Houston , Texas
Just a few more pics, still need to glue the bath floor down. I have tucked the vinyl floor under the laminate at the bath door and will put in an end piece that slopes down to the vinyl under the door and tack it down. Also have to drill a hold for the latch so doors don't swing open while underway.
James
ID:	44039   Click image for larger version
ID:	44041   Click image for larger version
____________
1970 Overlander
Old 08-29-2007, 05:38 PM   #16
1970 27' Overlander
Houston , Texas
Btw
I forgot to post that it worked better for me to lay across rather than lengthwise but that may change someday now that I have a little more experience but not anytime soon.
James
____________
1970 Overlander
Old 09-01-2007, 09:03 PM   #17
Uberphotos's Avatar
1968 22' Safari
Kalamazoo , Michigan
I'm about to put the same flooring down in my Airstream and am very excited with how well your's looks. My wife and I debated for a long time about the color... light or dark... we choose light are I am glad we did. (I just hope mine looks as nice at yours)
Uberphotos is offline   Reply With Quote
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 12:21 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 04:08 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 07:28 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 12:11 PM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 05:05 PM
