Old 07-10-2012, 10:58 PM   #1
1989 29' Excella
Beaverton , Oregon
Molding/trim on a wood floor
I'm struggling to find the right material to use to trim out my new wood floor in my '89 Excella. I've tried 1/4 round but that can't seem to take the radius of the nose end or the tail end. Plastic or vinyl looks cheap and doesn't do the wood floor justice. Any ideas?.
Blu4re is offline   Reply With Quote
Old 07-10-2012, 11:09 PM   #2
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Have you tried the base shoe trim? I think thats what it is called. Its about 1/4" thick or a little more. It curves a lot easier then corner round. Also have you tried steaming it to get the bends you want?
Just thoughts I had off hand. Have you considered some aluminum trim?
ddstech is offline   Reply With Quote
Old 07-10-2012, 11:16 PM   #3
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
aluminum cove molding. I bought mine at Ace Hardware.
Mike Brumback
WBCCI #1200
Grand Master is offline   Reply With Quote
Old 07-10-2012, 11:30 PM   #4
1989 29' Excella
Beaverton , Oregon
I'll give the aluminum a try. I wish I would have asked two attempts ago. Thank you!
Old 07-28-2012, 07:58 PM   #5
ddruker's Avatar
2000 27' Safari
Palo Alto , California
I used 1 inch wide by 1/8 inch thick aluminum bar in anodized finish, with stainless steel screws every foot or so as fasteners. See photos. I liked the ability to bend it around radiused corners. They carry Aluminum bar at Orchard Supply, Home Despot, etc. Make sure you get a piece that isn't scratched up.
My 27 foot trailer required three 8-foot pieces to finish out.
I've still got some details to clean up - glue from the PO still stuck to the walls, etc - but looking good.
ID:	164051   Click image for larger version
ddruker is offline   Reply With Quote
Old 07-28-2012, 08:04 PM   #6
1971 27' Overlander
THEODORE , Alabama
Rubber baseboard from Lowes or Home Depot works well making the turn on the curved walls
WUZENTME is offline   Reply With Quote
Old 07-28-2012, 09:44 PM   #7
ddstech's Avatar
Folsom , California
It looks awesome!
Old 07-28-2012, 11:20 PM   #8
Splitrock's Avatar
Sioux Falls , South Dakota
Originally Posted by ddruker View Post
That's kind of a high trophy case isn't it?
Old 07-29-2012, 09:51 AM   #9
ddruker's Avatar
2000 27' Safari
It gives you a commanding view of the trailer...
Old 06-09-2016, 08:05 PM   #10
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Old thread but I really like this aluminum molding. Has anyone else done this? Is it easy to work with, cut, bend around corners, etc.?
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 06-10-2016, 05:48 AM   #11
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
That looks beautiful! Thanks for sharing!
Dingo Girl is offline   Reply With Quote
Old 10-07-2016, 06:05 PM   #12
1971 31' Sovereign
Fribourg , Fribourg
i had the same issue on my trailer,
impossible to find aluminim trims on the market, not easy to bend them correctly, follow the curves, etc...
i didn't want to use rubber trim at all so i made a custom trim with 2 layers of aluminium,
i pressed both of them against the wall and then i drilled holes and assemble them with rivets.
ID:	273029   Click image for larger version
Silver Man is offline   Reply With Quote
Old 10-08-2016, 03:05 AM   #13
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
That is beautiful!
