Old 08-24-2010, 08:49 AM   #1
67twinkie's Avatar
1967 26' Overlander
Lancaster , Kentucky
Moisture barrier under laminate flooring?
Looking for advice on installing wood laminate flooring in my '67 Overlander. I will be using a laminate flooring that has the foam underlayment already attached - do I need to use a moisture barrier under the laminate? Thanks in advance.
67twinkie is offline   Reply With Quote
Old 08-25-2010, 04:37 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
I guess I'd contact the manufacturer of the flooring and do as they suggest for my application.
Old 08-25-2010, 05:12 PM   #3
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
A moisture barrier is needed for hydroscopic materials that are in contact with possibly wet soil - namely concrete and aggregate surfaces. Another time a vapor barrier is needed is when the flooring will be on a surface which, due to condensation from temperature differentials, may wet the laminate.
Your wood floor is not going to bring moisture or condensate to the laminate, therefore a vapor barrier isn't necessary. Condensate can form or collect at the base of the walls, where they meet the floor.
I know that isn't a yes or no answer, but it'll help you decide an answer to your question based on your own needs, usage and local weather.
TX-16
Dave Park is offline   Reply With Quote
Old 08-25-2010, 05:20 PM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Good question. I'm getting ready to lay Allure laminate and was wondering the same question. I stopped by HD today and spoke with one of their flooring people. He stated that there was no need to use anything underneath the laminate as it was vinyl coated. Anyone else have any thoughts?
Roadrunner is offline   Reply With Quote
Old 08-25-2010, 05:24 PM   #5
Dave Park's Avatar
2005 22' Safari
It is vinyl coated, but the machined edges are exposed board and are the usual point of failure on the topside if they become wet for any sustained period.
Whenever I have laid flooring I have always allowed a glue to dry (if a glue was appropriate for the brand and application) then applied a sealer to the joins. I did this on my tradewind and no problems.
TX-16
Old 08-26-2010, 06:17 AM   #6
67twinkie's Avatar
1967 26' Overlander
Thanks for the help.
Laminate Flooring Direction? Roadrunner Floor Finishes 16 12-06-2010 06:52 AM
Does vinyl flooring create a vapor barrier? eastbound Floor Finishes 2 12-09-2009 07:04 PM
To install a plastic moisture barrier or not... that is the question Director Floor Finishes 6 08-28-2008 10:35 PM
HELP with Laminate Flooring betsy28 Floor Finishes 17 04-22-2008 02:09 PM
Laminate Flooring Help! Safari Tim Floor Finishes 26 03-05-2005 04:31 PM
