Old 04-21-2008, 06:55 PM   #1
1986 Argosy
Moss Point , Mississippi
Marmoleum Flooring -Sheet or tile
Okay -I contacted the nearest Marmoleum supplier (Jackson,Ms) and I have color brochures. Now I need to know which to use - Sheet material or tile. I have a 1986 32' Argosy I am updating. Tile is also available that "locks" together. Sorry I cannot load pictures yet but I am going to learn how.
njunear is offline   Reply With Quote
Old 04-21-2008, 07:26 PM   #2
cameront120's Avatar
1972 25' Tradewind
Tile is preferred by some because they like the idea that they can align the seam with joint in the plywood subfloor. Sheetgoods that are glued down can crack over time where the plywood joints are. I would avoid the 'locking' tiles, as they are on MDF which does not stand up well to water and humidity.
North Vancouver, BC
Old 04-21-2008, 07:51 PM   #3
Mackhopp's Avatar
2005 28' International CCD
Ottawa , Ontario
Tile is always good in case of minor damage - much easier to replace a tile than fix a single sheet...
Whichever you choose, be sure to use a commercial floor sealer to seal the floor as well as a couple of coats of floor finish for ease of maintenance. Most marmoleums come with a polyurethane manufacturer-applied top coating that is UV cured, however this will wear down over time. So to maintain the appearance of the floor it's recommended to seal it and use a floor finish.
Moisure is a killer to marmoleum - so be sure to seal it well. It will swell if any moisture comes into contact with the sides/underside.
[SIZE=1]Michelle & family
[COLOR=Blue] 2005 28' International CCD
Mackhopp is offline   Reply With Quote
Old 04-21-2008, 07:59 PM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
For a DIY go with the marmoleum click. For a pro install go with the sheet.
Sheet can withstand water damage better than the click can. Plus with sheet you can drill right through it to mount cabinets or other items without worrying about expansion. You also don't need to worry about that 3/8" thickness you are adding when you put cabinets back in.
-Tim
theVAP - Airstream Podcast
Old 04-22-2008, 07:01 PM   #5
1986 Argosy
Marmoleum flooring
Thanks for the input.
Since I am going to have the flooring installed I think I will go with the sheet material. I will, however, do the carpet and vinyl removal myself as I may find some floor areas in this 20 year old trailer that require some repair. I also would like to sand the floor myself as the "professionals" sometimes just give it a lick and a promise.
It is my intention to remove the couch from the trailer and also the double bed in the back. I am not so certain about the base cabinet (Dinette) removal - are they difficult?
Old 04-22-2008, 07:47 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
We have marmoleum sheet in the front half of the Excella. I removed the vinyl tile that had separated at the seams and also removed the plywood sub-floor that somewone had added over the original. I didn't want to mess with a template so I opted to have the floor professionally installed, but had to sign a waiver to get them to do it over the original floor (they wanted to add the extra plywood sub floor again). The sheet wont crack as long as it cannot move up and down at a seam and the original has the seems along the floor frames hence no movement if the bolts are tight. It's been in two years with no trouble. We wanted the seamless look and also wished to avoid the inevitable separation along the seems when dirt gets in and undermines the adhesive.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-22-2008, 11:26 PM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Nope...it's all just attached with screws to the floor and walls...you'll be surprised how easy it all comes apart.
FWIW, we have had sheet Marmoleum down in our GlobeTrotter since March of 2002...no signs of cracking or deterioation of any sort and we are tough on it - over 25,000 miles since install. Also, lots of rain showers on our camping adventures here in the Rockies and lots of dirt tracked in. We are so pleased with it we are putting the same down in our Safari. The tough thing is just deciding which color to choose!
Shari
Marmoleum? StingrayL82 Floor Finishes 43 08-16-2016 06:25 AM
Marmoleum Flooring J-n-A Our Community 34 03-10-2013 11:13 PM
sheet vs tile linoleum slimitch Floor Finishes 25 11-20-2008 08:07 PM
Can I use Composite tile for flooring? tjj's63 Floor Finishes 5 06-06-2005 01:12 PM
Sheet, yes! Don in E Texas Our Community 0 07-06-2003 05:07 AM
