Old 11-06-2010, 11:12 AM   #29
jerbear315's Avatar
1966 17' Caravel
College Station , Texas
Images: 22
Marmoleum as countertops and floors!
Originally Posted by Klatawa View Post
We put Marmoleum on the floors and counter tops on our
safari and we use "Marmoleum Floor Finish" that we got from the flooring company that we purchased the Marmoleum from. We just clean the surfaces and wipe it down with the product on a rag and let it dry. Makes the floor and counter tops shine and stand out.
We are going to us Marmoleum on our next project a 1965 Tradewind
So, you can use it on countertops too? Interesting. Do you use the sheet for countertops or making a table top?
I was told by Forbo that you can just damp mop it but also put a wax finish(?) on it if the shine had worn off. I can barely keep my house clean, let alone put fussy countertops and flooring throughout the trailer. I guess if you don't use it often, then it isn't an issue not being able to buy their cleaner at the store.
They are sending me samples, but I appreciate the feedback.
I also appreciate the marmalade pun.
Jerri
jerbear315 is offline   Reply With Quote
Old 03-05-2011, 10:39 PM   #30
Lotus72
Lotus72's Avatar
1970 27' Overlander
Eugene , Oregon
Jerbear,
what did you end up doing? Would you post some pictures?
Thx
Eva
Lotus72 is offline   Reply With Quote
Old 10-22-2011, 05:50 PM   #31
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
marmoleum
Whats the word on Marmoleum in an airstream ?
I need to replace carpet and I don't want the typical "wood flooring".
I love marmoleum and will be installing it in my house.
1972 Ambassador Itn'l 29'.Custom Interior
1987 Avion 34X
1985 Avion 30R
Airline is offline   Reply With Quote
Old 10-22-2011, 06:09 PM   #32
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
We installed the click panel marmoleum in our Liner. Tim, Safari Tim, of the VAP, installed it in his Ambassador, Rob, robandzoe, has it in his SOTR and Shari, Insideout, has it in her trailers.
Bill
Just my personal opinion
Old 10-22-2011, 06:16 PM   #33
Airline's Avatar
1972 29' Ambassador
Thanks wkerfoot !
so,all of you used the "Click Type" ?
I am not removing cabinets.
Did you guys have it pro installed ?
1987 Avion 34X
1985 Avion 30R
Old 10-22-2011, 06:32 PM   #34
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I used the click panels because it was do it yourself. In addition, I had nothing on the floor. I believe that SafariTim installed with the cabinets in place.
Click panels are do it your self, sheet goods need a professional installer. If you go the click panels you need this: Marmoleum Click Tapping Block - Natural Linoleum - FLOORING
Bill
Thanks wkerfoot !
Old 10-23-2011, 03:59 PM   #35
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Thanks wkerfoot !
We used the sheet Marmoleum wall-to-wall in both our trailers. As noted in 2006, first was in our '64 GlobeTrotter, installed in 2002 and it was still in perfect shape when we sold it this last spring. We were so happy with it we installed it in our '56 Safari we have now. Both were installed professionally. You really want to do it right, I've heard horror stories of it bubbling if the proper glue & prep are not used.
Shari
Old 10-23-2011, 06:07 PM   #36
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Bill
Sheets are not rocket science. The key is a solidly attached base. I used 1/4 baltic birch with a grid of screws every 4 inches and use the correct Forbo adhesive for sheets.
Old 02-15-2012, 01:41 PM   #37
boise , Idaho
Sheet Marmo works well in all RV's and especially in Airstreams. It fits with the 'period'. Also a qualified installer can customize your floor to any of your specifications. Some even have 'wrapped' the entire interior with Marmoleum.
As to counter tops, Marmo and other commercial floors have been used for decades as counter top material. You probably have seen it on the surfaces of grocery store check out stands w/o even realizing it.
The durability of Marmo is...it is considered to be a 40 year floor if properly installed and maintained.
BarryCarlton is offline   Reply With Quote
Old 02-18-2012, 04:13 PM   #38
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Several Marmoleum threads over the years, almost everyone reporting satisfaction with it.
Here are shots of it being used through out my trailer since being installed in 2006, 2007:
on the galley counter
on the bathroom counter
flooring wall to wall through out
Sergei
SmokelessJoe is offline   Reply With Quote
Old 04-05-2013, 08:48 AM   #39
Luc
Luc's Avatar
1999 19' Bambi
Cape Canaveral , Florida
This thread started a while back: Should be perfect for feedback.
I am thinking of using Forbo Marmoleum 20" x 20" tiles in my trailer.
Some of you have experience with that. Any tips, warning or advice?
Luc
Luc is offline   Reply With Quote
Old 04-07-2013, 08:17 AM   #40
1976 25' Tradewind
Crawford , Texas
i have checked into Armstrong's brand...they only do sheet goods...rated better by Consumers Report...I think the top layer is different in terms of finish..and cleaning. i like the idea of Forbo's click floating floor also. Unsure what to do...Cork....or marmoleum...tiles or sheet...glue down or float?
MyAirstreamJoy is offline   Reply With Quote
Old 06-15-2013, 08:33 AM   #41
cdmagda's Avatar
Images: 51
I used the 13" tiles, thinking when floor rot repairs are needed, looks afterward like nothing happened.
cdmagda is offline   Reply With Quote
Old 06-15-2013, 09:29 AM   #42
InsideOut's Avatar
1956 22' Safari
Images: 108
Originally Posted by Lumatic View Post
Sheets are not rocket science....
True, however the Marmoleum sheet width is narrower than the trailer width - you will have one seam running the length or several crosswise. A professional can "weld" that seam with a hot seaming material that seals and blends (matching colors available) with the linoleum material making a solid sheet - no water penetration opportunities.
We have one welded seam that runs the length of our trailer - you'd be hard pressed to find it, I can't and I even know where it is.
Shari
Marmoleum Flooring J-n-A Our Community 34 03-10-2013 11:13 PM
My new linoeum floor Bryanhu General Interior Topics 23 10-20-2004 10:53 AM
Linoleum Tile On Sale fireflyinva Floor Finishes 5 07-21-2004 06:57 PM
source for high-end linoleum? Dave Cole Floor Finishes 3 10-02-2002 02:29 PM
