Old 07-28-2010, 12:06 PM   #15
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Originally Posted by dnrtheil View Post
Does Luan stand up to water the way exterior grade plywood does? I would guess that when the Luan gets wet it'll swell up.
Derek
I'm doing a test. I cut a 12" square piece and soaked it with water (more water than it may ever see) to see if it delaminates and how much. Going to check it tonight to see what happened.
adwriter73 is offline   Reply With Quote
Old 07-29-2010, 05:46 PM   #16
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Let us know how it goes... but I don't think luan was ever designed to be soaked.
hampstead38 is offline   Reply With Quote
Old 07-29-2010, 10:37 PM   #17
maison1306's Avatar
Replacing carpet
The carpet is out in my 2001 Excella, 30'. Was going to use 1/4" lauan but installer felt we should go to 3/8th's plywood. A little heavier but not that much. Not sure how they"re attaching it- either nails or screws. Then installing sheet of special moisture barrier over the wood. Then installing Mannington Adura plank vinyl flooring (3' X 5" X 1/8 thick). It will be glued to the moisture barrier with a special glue that will allow a plank to by heated with a hair-dryer and taken up if damaged and replaced.
Using the 3/8th's plywood also eliminates having to use any trim around the edges because the carpet and pad were cut away at the edge of cabinets and dinette. The 3/8th " hides the cut-away edges.
Hope it works ok.
Dan M.
maison1306 is offline   Reply With Quote
Old 07-30-2010, 05:03 AM   #18
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Use right size screws or nails
Whatever they attach to the floor, make sure they do not use nails or screws longer that the thickness of the floor. There are water lines, electric wires and black & grey tanks down there just under the floor. Someone attached a 1/4 in plywood to lay flooring and it hit a water line. Must have sat there for years slowly leaking. When I took the floor up to install a new floating floor, I pulled the nail and it looked like a little spring flowing from the hole. Big problem getting that fixed without dropping the belly pan.
ID:	107789   Click image for larger version
AirHeadsRus is offline   Reply With Quote
Old 07-30-2010, 07:50 AM   #19
maison1306's Avatar
Flooring issues
Good info to know about water/electrical lines under the floor!
Dan M.
cork, floor
1960 Tradewind needs floor work and help! WcfdPiper Repairing/Replacing Floor &/or Frame 2 05-13-2009 08:34 PM
Air Bags - piece of cake Pop Rivet Classic Motorhomes 2 08-28-2006 08:48 PM
Airstream Motorhome Cake LeeMo Our Community 7 10-07-2004 06:42 AM
Let Them Eat Cake! Gwen Stella's Kitchen 9 04-04-2004 07:04 PM
