03-07-2010, 07:37 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Laminate Flooring Direction?
We have purchased natural bamboo laminate flooring to lay in our AS. For those that have used floating laminate flooring, have you installed it lengthwise or side to side. Would you do it differently if you had to do it over again? Any tips? Any pictures? Thanks for the help!
TAC PA-5
03-07-2010, 08:28 PM
2017 30' Flying Cloud
2008 23' International
Keremeos
, British Columbia
Hi Roadrunner,
I haven't laid the flooring in an Airstream, but I have in our house. The joints need to be staggered for strength and looks. If you laid them side-to-side, you couldn't do that. I personally think lengthwise would work best. When you sweep, it will be lengthwise, so you don't want the broom sweeping dust into the tiny cracks. We did lay a floating cork floor in a much smaller trailer and tried to stagger the joints as much as possible. I hope this helps, but sorry I don't have experience doing this in an Airstream.
Lisa
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
03-07-2010, 08:31 PM
A.K.A "THE STREAM"
2010 25' FB International
Arlington
I laid mine in my 76 Argosy and staggered it by 12 inches. Rows of 3. Also when I laid mine I laid it Longways....like from tail to tounge length wise. Will make the trailer appear longer intead of short and stumpy.
Bad pics I know.
Shane
03-07-2010, 08:42 PM
1978 Argosy 27
Lacey
Bob,
My wife and I have just laid "floating linoleum oak" look in out '78 Argosy 27ft trailer. We attempted to stagger the 8" x 36" sections but due to the configuration of the trailer floor we could only stagger part of the trailer floor. But it turned out to look ok. We treated the plywood floor with BIN product to seal the old trailer smells and it also made the floor surface better to lay the linoleum down.
03-08-2010, 05:59 AM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
Bob,
We put down the laminate flooring in our trailer about 3 years ago. I decided to go side to side because of the expansion and contraction considerations. Had we laid it longways, we would have had a 30' end to end run. By laying it sideways we had 7 1/2' maximum run (and most areas less than 3 or 4 feet) which minimizes the product movement. We have had no buckling or even noticeable movement.
We don't feel side to side installation makes the trailer feel short and stumpy--if I had to do it again, I would lay it the same way.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
03-08-2010, 07:44 AM
Front to Back....
Bob,
We bought engineered wood that looks great and plan to install soon. I've read most messages over the years on this topic and have decided the tongue to tail-end layout looks best in most of the units.
Actually no one has mentioned the sweeping benefit (see earlier post) and that makes sense too.
I want to spray the forward endcap before I do the floor as the spray travels.
Steve
04-11-2010, 09:24 PM
2008 27' International FB
Venice
I did a floating oak laminate floor length way. I think it gives it a better look that way. When you install the floor make sure you adhere to the directions, leaving a space around the entirety of the floor for expansion. Much better than carpeting, easy cleaning. Look at my floor in my registry 1st page under "airdreamers".
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
04-11-2010, 09:39 PM
Ottawa
, ON
Originally Posted by Cantrell
Bob,
I agree this makes the most sense, even if it means more cutting.
Here in Canada, the real world is pretty darn cold in the depths of the winter, and I don't think I want to have to do it again due to expansion...
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
04-11-2010, 10:02 PM
1978 28' Ambassador
Morada
We installed floating flooring, length-wise...it was probably more difficult due to the fitting/filing, etc., but it looks great...IMHO, of course..
The vinyl, foam backed flooring planks (we used Prego) also helps insulate the floor to some degree...Ours have been down for about 1-1/2 years with good results...we like it, we used a Tigerwood finish...
Ray
Ray & Pat; Morada, CA
04-12-2010, 01:09 AM
1993 25' Excella
Full Time
, Anywhere USA
Our current pergo flooring is lengthwise, our new flooring is going in side to side. I think the way the current flooring is installed in our 25' trailer makes it look like a bowling alley. It will be removed in the next couple of weeks and the new flooring will be installed. I'll post before and after pictures.
Michelle & Leon
New England Unit
04-12-2010, 05:23 AM
2016 25' Flying Cloud
2005 30' Classic S/O
2014 Interstate Ext. Coach
Eddy
Laminate flooring
When we installed our laminate flooring, David from Roger Williams Airstream, suggested we glue down the planks at an angle starting in the door. It is impossible to keep the lines of the flooring straight with the cabinets and lines of the airstream. It looks odd to look down the trailer (from the inside of course!) and see a line from the flooring that is not parallel to the cabinets. We used a carpenter's square and marked a 90 degree angle at the middle of the door and used those lines to work out from the door. The finished result looks good, we have had no trouble sweeping or vacuuming. Good luck!
04-12-2010, 06:22 AM
1974 Argosy 24
Science Hill
, Kentucky
Kevin & Monique
New to A/S---Not to Honey Do's
Sweetie (lab) Snickers (lab) Blackie(lab)
Dotz(daschund) CB (daschund) Oh and 3 kids!!!
TAC# KY-3
04-22-2010, 07:36 PM
1966 17' Caravel
Averill Park
, New York
I think this looks great! Does anyone have any concerns/ideas about the weight of laminate flooring as compared to other choices?
04-22-2010, 08:25 PM
2002 27' Safari
Amarillo
JimS
When you glued the planks down, did you glue only the one's by the door or the whole trailer? The 90 degree direction..toward the front or toward the rear? Pictures?
Thanks.. Dan
12-05-2010, 09:00 PM
2009 34' Classic
Birmingham
, Alabama
What is the cost for the flooring? I just want a ballpark cost for the whole trailer 31'.
12-05-2010, 10:29 PM
Ottawa
, ON
It just occurred to me that if you want an unusual look (and are willing to put a little more effort into the job) why not try doing all the cuts on the bias, on a 45° angle?
It would certainly set you apart...
12-06-2010, 06:52 AM
We installed our flooring like Mouth's, side to side. It makes the cuts around doorframes, ect. much easier.
We floated our flooring with no glue or staples. No problems with expansion, moving or shifting.
