Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 07-07-2009, 07:09 PM   #1
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Installing Marmoleum
I want to install a sheet of Marmoleum between the galley and bathroom (basicly bedroom area) of my 71 Tradewind. I need a piece roughly 79"x40".
Dealer says he has a remnant I can have for $100. Dealer recommends screwing a specialty 1/4" ply to subfloor and gluing Marmoleum to this 1/4"ply. I have some 1/4 Baltic Birch Ply I can use. Any thoughts or recommendations on price and installation?
Pay no attention to the man behind the curtain- WoZ
Old 07-07-2009, 07:57 PM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Price sounds good. We installed ours directly to the 3/4" plywood. If your plywood is NOT new or you are going over another finish, then installing over the extra layer makes sense.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 07-07-2009, 08:02 PM   #3
Lumatic's Avatar
Shari
The plywood subfloor is the original 1971 factory. It is soiled but in good shape
Old 07-07-2009, 08:09 PM   #4
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
The whole idea of putting in a sub-floor is that you end up with a smooth surface that will not telegraph dents and dings through the sheet goods. If your floor is in good shape go for it. If you want a smooth job lay the 1/4" and fill the screw holes. It will also make it easier to remove the floor at a later date, such as 2049 or so.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 07-07-2009, 09:06 PM   #5
Lumatic's Avatar
Also, in this section there is only joint. If I don't add the 1/4" ply I would guess I need to fill the depressions from the bolts that hold the subfloor to the frame.
Old 07-13-2009, 04:37 PM   #6
Lumatic's Avatar
OK got the Marmoleum. The flooring place did not have the adhesive the manufacturer suggests and did not have any substitute suggestions as Marmoleum is true linoleum. He could order me a gal for $35 which is a whole lot more than I need.
Any suggestions on what else I could goo it down with.
I have some 1/4 Baltic Birch I am going to first screw to the plywood.
The floor guy suggested using contact cement for the edges and gluing the whole surface later if necessary.
Any ideas?
Old 07-13-2009, 06:13 PM   #7
InsideOut's Avatar
1956 22' Safari
Images: 87
Penny wise but pound foolish...???
I'd get (and have got) the adhesive the manufacturer recommends. It's formulated to "work" with their product...other glues may adversely effect the Marmoleum to a point of soaking through or chemically breaking it down. Even if you don't use it all...I think it's money well spent.
Shari
Old 07-13-2009, 07:51 PM   #8
Profile:  1963 26' Overlander
Agree, use the glue the manufacturer recommends, even if you have to buy extra.
Old 08-19-2009, 01:39 PM   #9
Lumatic's Avatar
OK, I got the Marmoleum and 10 times more glue than I need, but could not buy less. Now the instructions which come with the glue says after applying the glue use a 100# roller. This would mean 2 100 mile round trips for a rented roller. What do these rollers look like? Can I jury rig something? Are there other options? How bout I pull out my 45s and do the mashed potato?
Old 08-19-2009, 02:04 PM   #10
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
Originally Posted by Lumatic View Post
...use a 100# roller. This would mean 2 100 mile round trips for a rented roller. What do these rollers look like? Can I jury rig something? Are there other options? How bout I pull out my 45s and do the mashed potato?
How 'bout a full 40 lb flat sided (steel - no welds) propane tank?
Any oilfield related industries in your area? Many times there are unuseable cylindrical cut offs laying about shops waiting for the scrap bin. If you ask nicely, they may let you "borrow" one.
Sliding around a heavy object (instead of rolling) might "pull" the marmoleum out of position, possibly stretching it.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 08-19-2009, 02:04 PM   #11
Lumatic's Avatar
FYI
Just talked to the flooring guys. They said what they do if they don't have a roller is cover the marmoleum with a carpet scrap and slide around a heavy toolbox.
Marmoleum swelling! modarch Floor Finishes 4 06-04-2009 12:57 PM
Marmoleum Flooring -Sheet or tile njunear Floor Finishes 6 04-23-2008 12:26 AM
Marmoleum? StingrayL82 Floor Finishes 24 03-20-2006 03:08 PM
Marmoleum Flooring J-n-A Our Community 2 08-17-2003 04:28 PM
Installing new shocks j54mark Axles 18 02-06-2003 07:44 AM
