Old 09-29-2010, 06:11 PM   #1
RBC
fort Collins , Colorado
Installing Cork floor
I am going to put a cork floor in my 65. I can pull out all of the cabinets bathroom and beds. nothing but plywood floor. Is it best to cover the entire floor or should i leave everything in?
RBC is offline   Reply With Quote
Old 09-29-2010, 06:18 PM   #2
Images: 59
Depends on what cork you're using. If its $5/sqft laminate I would go around the beds and cabinets. I did this and its a lot of cutting and fitting.
If its glue down sheet goods I think I would do the whole floor.
Old 09-29-2010, 06:45 PM   #3
1972 Travelux Princess 25
Cobourg , Ontario
If you take out the cabinets etc and apply flooring, they will sit higher when you put them back. This can cause problems.
Best to fit the material without taking anything out. If in doubt hire a pro to install it, he will do a great job in a surprisingly quick time and the charge should be modest.
To give you an idea, in my area a pro will install carpet and vinyl in a 400 sq ft 2 bedroom apartment for $250 or less. I would guess $100 should be par for a trailer.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 09-29-2010, 07:14 PM   #4
2007 25' Safari FB SE
Eureka Springs , Arkansas
We thought about cork laminate, but our supplier talked us out of it.
He had numerous problems with moisture in kitchens and baths with expansion and deterioration, which resulted in replacement.
We used Aztex (sp?) vinyl tiles. Glue down, not "peel & stick".
Don't think that a 200 SF apt flooring price will be the same as a 200 SF Airstream! Nothing is square in an AS (That's why we love them)
I told my supplier, I'd install another AS for $2K labor and I don't want any work!!! I scribed all cuts and I'm happy how it turned out, but don't call, I'm busy!!!!.
This is how we learn.
Name:	IMG_4565 - Copy.JPG
triplenet is offline   Reply With Quote
Old 09-30-2010, 09:41 AM   #5
Cobourg , Ontario
I have some rental units and to save money, I started buying carpet and vinyl wholesale and hiring an installer. I was surprised how little he charged, and how fast he finished the job. He did a real nice professional job too, better than I could. That is why I say, hire a pro if you want a good job. The cost is surprisingly modest especially if you have done it yourself.
Old 09-30-2010, 11:20 AM   #6
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I was gong to install cork but the price is prohibitive. I think I will install vinyl. I was told that since an AS has a floating floor you do not want to install it under the furniture or appliances. Go up to them and install trim. The original carpet was in my Overlander and it was not installed under any of those areas either.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 09-30-2010, 02:55 PM   #7
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
I installed cork (from Lumber Liquidators). Glue down. Ran it up to cabinets and then installed aluminum coving. Not expensive. Easy to cut and install.
-Michael
TAC CA-12
"All things in moderation, including moderation"
- Mark Twain
bevman is offline   Reply With Quote
Old 09-30-2010, 03:34 PM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Since you are removing everything you will have a large area relatively flat and only straight cuts for four walls, easy job professional or not, leaving in and cutting around as others have said not easy for anybody, ALL cuts have to be exact. Professionals only do it fast and cheap when it is an easy job, or if they make a mistake on the quote.
Old 09-30-2010, 03:45 PM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I did cork in my 82 280 MH. It looked great, and holds up very well. I was lucky to find a few boxes on EBAY from someone who had bought too much.
I recommend the "Allure" vinyl laminate though, after using that in two Airstreams.. it's sold at home depot . It is a breeze to put in, water will not damage it and it has sticky overlapping ends that make the install work well.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-30-2010, 05:19 PM   #10
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I installed a floating cork floor that we are very pleased with. Check out my posts #21 - #24 in this thread. http://www.airforums.com/forums/f461...s-65213-2.html
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-30-2010, 06:24 PM   #11
2003 22' International
Waverly , Pennsylvania
If possible take your trailer to a flooring installer and get an on-site quote, or take them some photos. I was planning to replace carpet with laminate and went to a local flooring retailer for a quote. They gave me an install quote based on the square footage of flooring that was needed.
The installer called me and said the install quote was incorrect because of all the cuts necessary and the time involved. The actual install price was three times the original quote.
nayl is offline   Reply With Quote
Old 09-30-2010, 06:46 PM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
We had ours professionally installed after doing some of the prep work ourselves (smooth, smooth subfloor). No cabinetry removed.
The total was well above $1k but worth it. These trailer interiors are only as nice as their fittings.
We fulltimed in highly humid South Texas and had zero problems with kitchen or bath floors. Same for later in storage when humidity stayed above 90% (and I got around to placing a de-humidifier in the trailer).
Cork is simply outstanding: as quiet as a carpeted trailer, with the wood floor advantage of cool in summer and warm in winter . . with a bit of cushion.
Cork floor in the bathroom FreshAir Floor Finishes 7 05-10-2010 09:00 AM
cork floor for 1992 firedog 1990 - 1993 Excella 3 07-24-2008 04:32 PM
Cork floor Pahaska Floor Finishes 73 07-24-2008 01:46 PM
Cork floor Charcigar Repairing/Replacing Floor &/or Frame 42 03-02-2006 01:25 PM
Cork Floating Floor ClassicRides Repairing/Replacing Floor &/or Frame 21 12-01-2005 08:12 PM
