Old 12-07-2011, 11:21 AM   #1
1967 30' Sovereign
Farmington , Missouri
Installing a new sub floor...
Is there any need to leave an expansion gap where the new sub-floor meets the wall in my Airstream? I plan on removing the old sub-floor and repalcing it with new 3/4" plywood that I will seal before installing my floor covering.
Thanks for all the help!
SeanL is offline   Reply With Quote
Old 12-07-2011, 11:35 AM   #2
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Is your existing subfloor so rotten that you can't use it as a template? If not I would just use exactly the dimensions that are existing. In fact that is what I did in my replacement.
You have to remember that your metal walls will also expand with heat, albeit at different rates of expansion.
However for whatever the info is worth from one 1959 trailer, my new floor cut exactly to old dimensions had a 1/8" to 3/16" gap on the sides and was flush on the curved ends (and yes I had marked where the c-channel previously was so this is not due to flex of the shell, at least not as a result of the rebuild--it could have occurred over 50 years).
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 12-07-2011, 11:38 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Sean....the sub floor is designed to extend under the walls...which in turn are fastened to the floor and frame together. I suggest you kick back and read some of the floor replacement threads here. UNLESS, heaven forbid, you plan on screwing a 3/4 in plywood floor on top of the rotted old floor. In that case you would probably need a small expansion gap.
Old 12-07-2011, 11:43 AM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings SeanL!
Welcome to the Forums and the world of Vintage Airstream ownership!
I am not absolutely certain that I completely understand your project, but if my understanding is correct, you may be attempting a repair that will become a future headache.
My impression is that you are attempting to repair floor rot, and overlaying the existing floor is not a good plan. Your Airstream has semi-monococque construction meaning that the floor, body, and frame work together as a unit. When the wood floor fails and needs to be replaced the process is somewhat involved . . . in fact, for a total floor replacement, it is often recommended that the body be completely separated from the frame; although, it is possible to completely replace the floor without doing so with some extra planning and piecing of the floor segments.
When the floor is replaced, the lower section of the interior walls is removed by drilling out the pop-rivets that attach the aluminum to the wall structure. This process reveals the channel at the base of the wall where the wall sections are attached to the floor and frame. It is necessary to access this cavity to release and remove the original floor (or what remains of the floor) - - then the new floor is inserted under/within the aluminum channel and the attaching hardware is reinstalled. There are a number of threads here on the Forums detailing the floor replacement process -- try Forums searches for floor replacement or full monty - - you will find many different approaches to the problem.
On the other hand, if you are just wanting to prepare your coach's sound floors for new floor covering, you would want to proceed with something less than 3/4" plywood as you would not want that much additional weight when the payload capacity is not huge. My Overlander had sound floors, but the original plywood had numerous imperfections so my sheet vinyl installer insisted upon a new luan underlayment prior to his installation - - smoothed up the floor and resulted in a beautiful job.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 20 09-10-2012 11:32 PM
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Floor replacement question: to do it right the first time! Eric H Repairing/Replacing Floor &/or Frame 7 12-06-2011 09:19 AM
Mismatch of floor and outrigger width MtnMDStan Repairing/Replacing Floor &/or Frame 3 06-19-2011 02:44 PM
Floor channel size when installing 3/4" plywood? surfpod Repairing/Replacing Floor &/or Frame 8 05-03-2011 12:25 PM
