Old 05-06-2013, 06:37 AM   #1
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
Installed Costco Golden Select Click Vinyl Floor
Well....decided the pink carpet had to go! So decided to go with Click Vinyl from Costco..$37.99 for 19.54 sq ft/box. Things went very well, carpet removed with several banged up knuckles and sore hands after several hours with a utility knife. Floor under the carpet was in perfect shape with no water damage or lifting seams. The vinyl floor is very easy to work with. For straight cuts you just score the surface and snap it off, much like drywall. For the many angle cuts, I used a jigsaw in combination with the utility knife...again very easy to cut. The pieces clicked together very easily...and I have installed many types of click flooring and this was by far the easiest. It took me a full day to remove the carpet and install the floor, and then a morning to get the trim work done, measure, cut, stain, and nail gun. % boxes were required for install. I left the bedroom with the carpet...nicer on the feet and very little traffic there. So now it looks like a new trailer...very happy with the results. Attached some photos.
Name:	original carpet.jpg
ID:	185253   Click image for larger version
Name:	carpet gone 1.jpg
Name:	carpet gone 2.jpg
ID:	185255   Click image for larger version
Name:	new vinyl click flooring 1.jpg
Name:	new vinyl click flooring 2.jpg
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 05-06-2013, 06:41 AM   #2
Gilmurr's Avatar
Smile Make that 5 boxes...not % boxes of flooring
Have to love the Caps key when you don't want it!
David & Andrea
Old 05-06-2013, 07:10 AM   #3
M. Smith's Avatar
2012 25' Flying Cloud
Tuttle , Oklahoma
Nice work! Looks very good.
M. Smith is offline   Reply With Quote
Old 05-06-2013, 09:16 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Nice result!
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-06-2013, 09:26 AM   #5
2004 28' Classic
austin , Texas
Looks good! Did you remove the carpet everywhere, for example from under the couch? If not, how did you finish off the edges in those places?
Ntex is offline   Reply With Quote
Old 05-06-2013, 10:53 AM   #6
Gilmurr's Avatar
Vinyl Click floor
I left the carpet under all the cabinets and trimmed as close as possible...needs a sharp knife. I unbolted the front of the couch from the floor to remove the carpet which only went about a foot under. Placed the click flooring about the same distance in. I then put screws into the floor leaving about 1/4" above the surface to prevent the flooring from sliding, but I am quite sure that would not happen anyway. I also cut the flooring so the coach legs were on the plywood floor as the new flooring needs to "float". I stained quarter round to cover the 1/8" space the flooring needs around the perimeter
David & Andrea
Old 07-23-2014, 09:52 AM   #7
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
How did you attach your trim work-to the floor or the wall.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-23-2014, 10:59 AM   #8
Gilmurr's Avatar
Trim work attached with finish nails and nail gun to the wall and cabinets.
David & Andrea
