Old 12-20-2003, 04:42 PM   #1
'65 Caravel 17'
jlovelady's Avatar
2001 34' Limited
1965 17' Caravel
Lufkin , Texas
Installation of Harwood Floor
I plan to install a Pergo type flooring throughout a '93 Excella 34' long with a queen bed. It has a dinette and a side sofa.
Any advice will be appreciated.
jandml@lcc.net
jlovelady is offline   Reply With Quote
Old 12-20-2003, 05:06 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Jim!
While I didn't handle my own installation, I do have laminate floors in my '78 Minuet that were installed by Fowler Interiors in Symsonia, Kentucky. The Minuet posed some special problems due to its composite aluminum floors, but the same product should perform beautifully with the standard Airstream floors. The Fowlers used Armstrong laminate flooring with Quiet Walk underlayment fabric (this was in addition to the felt attached to the back of the Armstrong laminate panels). The floor is exceptionally quiet and comfortable underfoot. It is available in a number of wood grains as well as other patterns as well - - my coach has the light cherry that is a close match for its cabinetry. It has been nearly a year since installation, and I am quite pleased with the results.
Good luck with your decision!
Kevin
Kevin D. Allen
AIR #827
Old 12-20-2003, 08:10 PM   #3
Jim,
Good luck on your project. This subject has been dealt with at length on these forums. Do a search on both "Pergo" and "laminate flooring" and you will come up with a wealth of information.
Like Kevin, I've had mine over a year now, and it is a great improvement!
Mark
