Old 03-03-2010, 11:23 AM   #1
1977 Argosy 24
Milltown , Wisconsin
How to remove floor tile in 1959 SOB's
We are redoing a 59 Mallard camp trailer and it has the original 1' square tile on the floor. It is glued down with some black tar like stuff. We have tried a heat gun but that didn't help any. Does anyone have any ideas on an easier way to remove this old floor tile. Thanks Brian
ventport is offline   Reply With Quote
Old 03-03-2010, 11:27 AM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
They can be VERY tough to remove. I used floor scraper, putty knife and wood chisel on my 1963 Silver Streak. Some just popped right off intact, others chipped up in tiny pieces. Where a good mask as old flooring usually contained asbestos.
SilverHoot is offline   Reply With Quote
Old 03-03-2010, 11:48 AM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I found out by accident that water softened the tile mastic on my '48 Boles Aero.
Water can cause other problems like plywood delamination quickly so be careful.
And yes, there is a good chance that old tiles can contain asbestos.
Good luck on the project.
Sam
samb is offline   Reply With Quote
Old 03-04-2010, 09:53 PM   #4
1963 19' Globetrotter
Moline , Illinois
I have rented an electric tile scraper /removal tool at Home Depot that worked very well for getting old tile off plywood. To get the remaining adhesive off I then used a heat gun and chisel followed by paint remover for a final cleanup. Just is no easy way to deal with this job. Take the appropriate precautions to deal with the asbestos hazards.
63air is offline   Reply With Quote
Old 03-04-2010, 10:18 PM   #5
vinstream's Avatar
1962 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
The COLDER the better! It becomes very tacky the warmer it gets... You need to chip it out! It is a lot of work!
Good Luck! Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Bath room floor tile ? Robbie R. 1997 -2001 Excella 3 07-11-2009 08:42 PM
1967 Caravel floor tile 1967-Caravel Floor Finishes 3 03-31-2009 12:52 PM
Remove toilet to to put in new tile dmadam Sinks, Showers & Toilets 2 11-02-2004 03:30 PM
9x9 floor tile flyski Repairing/Replacing Floor &/or Frame 4 10-22-2003 01:45 PM
Tile Floor billhabing Repairing/Replacing Floor &/or Frame 10 04-19-2003 12:08 PM
