Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 09-16-2014, 02:49 PM   #1
AStreamJake's Avatar
2003 25' Safari
Livingston , Texas
How to Fasten Underlayment to Subfloor
I'm in the process of installing a glue-down cork floor in my 2003 Safari. My subfloor is in great shape, and I don't want to glue the cork tiles directly to it, so I'm now cutting 1/4" Tri-Ply (from Home Depot) to use as an underlayment. My question: How should I fasten the underlayment to the subfloor?
The cork dealer (icorkfloor.com) tells me to use screws spaced every 6". I'm concerned that even these, since they're countersunk, may pop through what little of the 1/4" floor remains after drilling the countersinks. And, should I ever need to remove the subfloor, I'd have to find every one of those screws by scraping the cork and glue off of their heads in order to unscrew them.
The other option is staples. This seems to be what most of the professional floor installers use (and what my local flooring guy recommended) but will the staples hold up to the 'moving floor' of an Airstream as it travels down the highway, or will they just pop/pull right out?
Any suggestions and comments on your past experiences would be appreciated.
AStreamJake is offline   Reply With Quote
Old 09-16-2014, 03:17 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
How about a quality waterproof double-sided tape you could scrape off if the floor ever fails, say at six inch intervals. If that would work, and I've never seen it done, why not fasten the cork to the subfloor with it.
Doug and Cheryl
Old 09-17-2014, 05:20 AM   #3
2003 25' Safari
Livingston , Texas
double-sided tape for subfloor
dkottum - the guys at Lowe's and Home Depot swear by the double-sided tape. Our local Home Depot even uses double-sided tape to hold the large sale signs posted on the walls of their store. They've told us that they have to pry the signs loose when done with them.
I'm not brave enough, however, to be the guinea pig who is the first to use it in for Airstream underlayment. Call me chicken! I'm looking for the tried and true.
Old 09-17-2014, 06:33 AM   #4
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Why don't you want to glue the cork to the sub-floor? To be able to remove it easily later on? I would skip the underlayment and use double sided tape to fasten the cork to the sub-floor like Doug suggests.
Lance
Lance M is offline   Reply With Quote
Old 09-17-2014, 05:32 PM   #5
2003 25' Safari
Livingston , Texas
Looking for more than a temporary fix
Well, I never thought of the double-sided tape, and the underlayment is already cut and is in place now (but not yet fastened). Although double-sided tape is an interesting concept, I don't want to be the first to try it and it's not an approved installation method for the cork flooring I'm buying, which is glue-down only.
Frankly, double-sided tape sounds more like a temporary solution and not the higher quality job I'm looking for. Although I could see myself at some future time wanting to again remodel and put down yet another floor, it won't be anytime soon. This go-around has worn me out, so if I do change floors in the future, it'll be in a decade or two. Probably right before they move me into the nursing home!
Should I have an underlayment installed with my new cork floors? Dickandvicki Floor Finishes 9 05-20-2014 08:36 AM
how to fasten tail light assembly '73 Soverign cuyd Lights - Interior & Exterior 3 06-22-2008 01:08 PM
Underlayment on top of new floor? mbatm01 Repairing/Replacing Floor &/or Frame 5 10-30-2004 03:21 AM
Plywood underlayment information Pam Repairing/Replacing Floor &/or Frame 1 07-22-2004 02:51 PM
Sealing the Subfloor?(Pergo!) KingPing Repairing/Replacing Floor &/or Frame 4 02-12-2003 06:45 PM
