Old 07-21-2016, 06:10 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Has anyone used this flooring?
I need to replace the floor in our AS. I've been reading about the experiences of others who have done the same. There seems to be many options and I have been looking at as many as feasible.
Today I went to a local flooring store and the gentleman I spoke with recommended Armstrong Lux Plank with FasTak. It is a Luxury Vinyl Floor with a sticky back and you lay it right onto the subfloor. It stays in place but can be removed if a section is damaged. Just use suction cups or a knife on and edge and peel it up. Here is a demo on You Tube,
Old 07-22-2016, 12:59 PM   #2
Hans627's Avatar
No feedback from anyone but I decided to purchased this floor and did so today. As soon as it cools down I'm going to start the installation process. Hopefully it goes well.
My biggest concern is temperature differences. The specs say 55 to 85 degrees F. But the floor specialist says that all the major producers have such a temperature range. He said he has seen it installed in garages with no heat and sunrooms (no AC) with full sun all day with no issues on either end of the spectrum. Hopefully he is correct. I guess we'll see!
Old 07-22-2016, 02:33 PM   #3
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Just did our 27FB with Shaw Forte LVT. Snap together with no stickum. I ended up pulling out all the seating and cabinets except the ones that went floor to ceiling. We're 100ē and no sign of problems from expansion. Pictures when you are done!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 07-22-2016, 02:52 PM   #4
hippiechick's Avatar
1966 24' Tradewind
versailles , Kentucky
We considered this type of flooring also. Hope it works out well for you. We had purchased cork patterned Allure vinyl planks several years ago before some of the experiences here showed gapping with temp changes. My top choices were LVT and marmoleum. If we have issues with the Allure we will replace it. But since we have it we're gonna give it a try. I went to a local boat sales to see the LVT. It looked great. Would enjoy seeing pics of your install. Valarie
hippiechick is offline   Reply With Quote
Old 07-23-2016, 12:46 PM   #5
1969 27' Overlander
Scottsdale , Arizona
Yes I have used it in several AS floors. So long as the floor old covering & glue is removed & sanded down enough to remove loose older glue. What ever is still stuck that is difficult to remove -is your choice to use heavy 80 grit sandpaper or just leave it as if it's difficult to remove-(it's staying) not coming up easy. then just be sure the surface is very smooth.
2nd use Spray on adhesive 3M 90. Do sections at a time- Preferable entire floor surface is sanded smooth, dust removed, so the glue doe not get on floor mounted furniture or walls USE shields or tape off areas where you do not want glue. Use plenty of common sense. Have your center lines drawn out and stay true to your lines. If one comes up that's OK- use more spray glue to secure it and weigh id down. Be sure to not ooze any glue at border so weigh does not become glued or use wax paper for repair sheets to separate weight from tile as you can use a blow dryer to soften the wax paper and remove it. Hope that helps.
BFSSBN is offline   Reply With Quote
Old 07-23-2016, 03:33 PM   #6
Native143's Avatar
2013 20' Flying Cloud
Dunedin , Florida
remove old flooring??
My old flooring (vinyl sheet) is in good shape, just boring. I want to install vinyl planks. Do I have to remove the present flooring? And also, I do not/cannot remove the galley/wardrobe but can remove the seating, so I can work around that? And just trim to fit? Or is this even feasible? Thanks.
"I'd rather rust out than wear out"
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 07-23-2016, 03:52 PM   #7
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
In 2010 we pulled out the carpet of our 1990 Excella 29' and put down Konecto Sierra Plank flooring. It is a vinyl flooring that sticks down but can come up if necessary. Still looks great, and nothing has tried to pop loose even on the edges. Has withstood the heat of Atlanta summers, and the AS being exposed to direct sun for part of the day, the coach does get very warm!!! Not Phoenix hot, but very warm. Some of the plank end joints have opened very slightly. Wife doesn't like that, but I think it actually makes the floor look like that in an older home where the floor boards have opened a little with age. The Konecto planks are wood grained vinyl and textured so it is better in some ways than actual wood in that the texture keeps it from being slippery. Good Luck on your floor.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 07-24-2016, 09:14 AM   #8
1988 34' Excella
Monteagle , Tennessee
Has anyone used any of the faux teak boat produces ? Yes they are pricey but they seen to have all the durability issues covered and that would seem to make them a "one and done" forever solution. I think that a Lux. Product like that would improve resale? Any thought ?
Tyndale is offline   Reply With Quote
Old 07-24-2016, 12:33 PM   #9
Tomboy's Avatar
2015 25' Flying Cloud
Long Beach , California
As long as your existing vinyl is not bubbling, cracking, etc., you can install new flooring right over the top of it.
Tomboy is offline   Reply With Quote
Has anyone tried this flooring? wannaroam Floor Finishes 164 10-18-2012 08:15 AM
Anyone used Konecto Flooring? scotta Floor Finishes 9 03-29-2011 12:59 PM
Has anyone matched factory flooring in 1998? redstart Floor Finishes 10 02-13-2009 06:50 PM
has anyone used sisal carpeting for the floor? zoeb nj Repairing/Replacing Floor &/or Frame 0 08-31-2005 03:58 PM
has anyone used Gords polish? 3x2x4sp389 Cleaning, Stripping & Polishing 6 04-06-2005 07:18 PM
