Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 06-26-2007, 02:49 PM   #1
wannaroam
wannaroam's Avatar
Profile:  1978 31' Excella 500
Harmony , Pennsylvania
Images: 34
Has anyone tried this flooring?
I am shopping for flooring for the AS and have been debating the merits of the various types. I stopped at a local store and they showed me Konecto. This is a floating vinyl plank floor, very flexible and water resistant.
Has anyone tried this?
You can get more information here:Welcome to Konecto.
wannaroam is offline   Reply With Quote
Old 06-26-2007, 03:18 PM   #2
RUSSELL
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Smile Hi,
I looket at a lot of floors and put in carpet all the way.I took out the piece of linoleun out and carpet the whole trailer with 1" padding and the carpet was a heavy duty office carpet. We wanted to have it warmer in the AS. We go to to Alaska every year. Except this year when they had to remove a melenoma out of top of my head.
Regards from Russell in sunny and hot Tucson Az.
RUSSELL is offline   Reply With Quote
Old 06-26-2007, 04:14 PM   #3
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Actually, I'm glad you posted that link. How much is it?
I looked again at your post and you said "floating." Ours was glue down. I'll have to study the link more and figure out how it works.
We put something very simular down in our new Maternity wing of the hospital I used to work out some years ago. It held up well, was warm on the feet, and looked great.
Do you have a store near by that sells it?
Marc
Old 06-26-2007, 04:19 PM   #4
cooperhawk
The Hawk's Lair
cooperhawk's Avatar
Profile:  BACK WOODS , Minnesota
I installed a Pergoe floating floor in our motorhome last year, and we love it. Easy to keep clean, and looks great too.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 06-26-2007, 04:37 PM   #5
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
A very interesting product. I watched the vidio. The only question I would have is you have to have a strong "Clean" floor underneath. Vinyl will transfer and surface irregularites over time.
I installed a Floating Armsrtong flooring in my trailer last year. In doing that job I removed everthing but the kitchen sink cabinet to reduce cutting and the need for molding. The removal only took about an hour. In areas where I had to screw down anything while reinstalling the cabinets I drilled an oversize hole in the flooring to retain the floatinf aspect. You may want to consider that approach.
http://www.airforums.com/photos/show...?i=15045&c=507
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 06-26-2007, 04:38 PM   #6
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Interesting. Would be less weight than real wood.
Old 06-26-2007, 07:24 PM   #7
wannaroam
wannaroam's Avatar
Images: 34
Thumbs up re: Konecto
Russell - with my two dogs (messy) and my hubby (messier) carpet isn't an option.
3Ms75Argosy - if you opt for the plainer design it is only about $1.69 sf ! If you go with the fancier design with more wood grain look it is about $3.60 sf. The product is very flexible and isn't glued down to the floor, it glues to itself and then floats. You can then take a plank of two out if need be. Might be good in case you have a leak and need to check/repair floor.
HowieE - according to the salesperson, and the info on the back of the samples it will go over and hide small irregularities in the subfloor.
cooperhawk - The things that I didn't like about the pergo was the concern over the mdf layer with the potential of getting wet. Not that my AS would ever have a leak, though. *sniff*
What I like about this is it has a nice feel to it, is very flexible, not too thick so no door issues from the floor being too high, and is very water resistant. The higher end product has a fairly realistic wood look to it too. The sample is marked on the back:
Completely waterproof
guaranteed not to chip or crack
absorbs sound
covers surface irregularities on sub floor
cuts and fits easily
No adhesives required
....and more but that's the pertinent parts
I think that we may go with this.
Old 06-26-2007, 07:42 PM   #8
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
I installed Marmoleum linoleum 13" squares in my Bambi II last year. They needed to be glued down individually so it was alot of work but well worth the effort. My primary criteria for choosing this type of flooring was I wanted it to have the same height as the original flooring so I could install it underneath the cabinets, walls and gauchos. It is as close to the original linoleum as I could find. I went with the glue-down flooring instead of the "float" or "click" styles because I didn't want to install floor moulding to cover the gap that needs to be left between the wall and floor.
WBCCI Region One
"Repression provides a temporary solution." ~ Paul Williams
yukionna is offline   Reply With Quote
Old 06-27-2007, 12:08 PM   #9
dnrtheil
dnrtheil's Avatar
Profile:  1964 24' Tradewind
Portage , Michigan
That's the stuff we are putting in Felix as soon as we get a chance. I was under the impression that Home Depot was only place that had it for sale. We have had a sample (HD gave us a sample soon after it came out, now you have to return any samples) in Felix for the past two months, even during remodeling it has no visible damage.
Derek
dnrtheil is offline   Reply With Quote
Old 06-27-2007, 01:19 PM   #10
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
I don't know about this brand but was considering vinyl planks in the past. i contacted the manufacturer who told me installing in a TT was not recomended because of the extremes in temperatures when in storage.
But then I have put other unrecommended products in my coach with no problems.
PS-I ended putting in wood flooring. That manufacturer did not recommend it either.
Are birds ever free from the chains of the skyway? BD
Old 06-28-2007, 03:28 PM   #11
Diana Langley
Diana Langley's Avatar
Profile:
Images: 13
How much of a gap do you need to allow for flexing where the floor meets the walls? Do you just leave it as a gap or do you fill it with foam, felt, or something else?
Pet Sitters take the "Board'em" out of Travel !
http://www.pawprints-petsitting.com
Diana Langley is offline   Reply With Quote
Old 07-30-2007, 05:10 PM   #12
highmark
highmark's Avatar
Profile:  1977 24' Argosy 24
Swan Lake , Montana
Thumbs up Konecto - the floor I have been searching for!
Hats off to "wannaroam" for putting out the information on Konecto flooring. My opinion - this is the greatest flooring on the market - completely waterproof - very nice looking and the directions make it seem easy to install. I am ordering the "Prestige" series in "Sunset". I will add to this thread when it arrives and I have it installed. Anyone looking for a low maintenance flooring solution should take a second look at this! Be sure and look at the actual product samples - they should be available at your local carpet/flooring store. Carol
highmark is offline   Reply With Quote
Old 07-30-2007, 06:01 PM   #13
klevan
klevan's Avatar
Profile:  Albuquerque , New Mexico
What About the Flexibility?...
This looks like a product inherently designed for Airstreams... until you read the subfloor requirements.
"All subfloors must be sound, solid and have little flexibility" in big bold letters with extra shading.
Airstream floors are constantly flexing as you roll down the great highway of life.
Ken Levan
2005 Chevy 2500 HD Duramax/Allison
Formerly WBCCI #8654
klevan is offline   Reply With Quote
Old 07-30-2007, 06:52 PM   #14
Jaxon
E Pluribus Aluminus
Jaxon's Avatar
Profile:  2005 30' Classic
Originally Posted by klevan
"All subfloors must be sound, solid and have little flexibility" in big bold letters with extra shading. Airstream floors are constantly flexing as you roll down the great highway of life.
Anybody called "Konecto Flooring" and asked if it's OK for RV's-trailers?
Bill & Kim's Marvelous Adventure
with Catahoula Charlie
30' Classic
F250 Diesel
AIR 9218
Jaxon is offline   Reply With Quote
Flooring ideas ALANSD Floor Finishes 42 02-09-2008 01:59 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-06-2006 12:00 AM
Great Flooring Price melprice Floor Finishes 0 07-08-2002 09:48 PM
Replacing the flooring - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 2 06-10-2002 08:59 AM
Removing old flooring and enhancing exisiting floor? Andy R Floor Finishes 4 05-18-2002 01:56 PM
test
