Old 01-06-2008, 01:42 PM   #99
reday's Avatar
2003 31' Land Yacht 30
Old Hickory , TN
Flooring Update...
I have finally gotten far enough with my flooring and furniture relocation to post a picture. Used the Sierra Plank Truckee. I have more info on the project posted at http://web.mac.com/reday.
Ralph & Margie Day
Lizzy the Borderline Collie
Old Hickory, TN
Between 'steams...
reday is offline   Reply With Quote
Old 01-06-2008, 02:31 PM   #100
reday's Avatar
Old Hickory , TN
Missing picture...
Need to quit messing around with this and go watch football. Here's the picture I managed to delete in the above post.
Ralph & Margie Day
Old Hickory, TN
Between 'steams...
Old 01-08-2008, 08:23 PM   #101
1973 31' Sovereign
Portland , Oregon
Images: 22
I have recently noticed that while some Home Depot stores do not seem to sock any of the Trafic Master Allure flooring that there is a pretty broad selection of colors in their online store at homedepot.com. They even have some types that resemble tile rather than wood. One interesting feature of the website is that you can check local store stock if you set your home store correctly.
I saw some of this material in stock at one of my local HD stores and was very impressed with it appearance. I am seriously thinking about using it for a large basement room as well as for my Airstream.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 01-08-2008, 09:00 PM   #102
reday's Avatar
Old Hickory , TN
It appears to be the same stuff. Even the tile store where I bought the Konecto alluded to that. There are 3 different lines of "wood grain" product see Welcome to Konecto. Not sure which Home Depot is carrying under their brand. There are 5 tile lines. The tile is supposed to start shipping soon if it has not already.
I liked being able to check out the samples and see what I was getting which I could not do at Home Depot. I paid a little more, but I appreciate the help that you get from people who specialize in their product.
Would like to comment on the fact that I have already seen where expansion may be a bigger issue than I thought with temperatures swinging like they are (we have gone from 17 to 70 degrees over the last couple of weeks.
I installed at the recommended temp, but in my application, I have many corners and places that I had to lay the tile completely around meeting back on the other side also spots where it is certainly not floating. I can see gaps appear and shrink back. Hopefully this will not be an issue or I may have to glue down like others have mentioned or figure out how to make more of it truly floating.
It looks like in TT installations you may not have as much of the above issues as in a MH. Also, even though their may be more cutting required, laying crosswise would lessen the expansion and contraction... I chose lengthwise for looks...
We will see if it was the right choice.
Ralph & Margie Day
Old Hickory, TN
Between 'steams...
Old 01-09-2008, 08:41 AM   #103
LookingThroughALens
aturner4u's Avatar
1976 Argosy 24
Marietta , Georgia
Images: 20
We have noticed that expansion is very much present in the Allure flooring. We installed when the temps were too hot (85+). At normal temps there are a few gaps. Camping when it was COLD this past week the gaps were a bit more noticable.
Overall the floor is really nice. I ran a swiffer over it before the open house at the CanOpener and it was clean. It is SOOOO much better than the carpet. It's not perfect but neither is our 30+ year old trailer.
In nature, light creates the color. In the picture, color creates the light. --- Hans Hofmann
aturner4u is offline   Reply With Quote
Old 01-19-2008, 10:27 PM   #104
1978 28' Argosy 28
Custer Park , Illinois
I have a 28' Argosy Motorhome and I've read all the statements concerning the positives and negatives on using the TT flooring. We currently have carpet and are looking at removing it and installing the TT flooring. Can anybody let me know: Do I have to cut around the couch and chair base mounts when installing the flooring or can I just attach it through the flooring?
betsy28 is offline   Reply With Quote
Old 01-19-2008, 11:47 PM   #105
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
I did both. Where I could easily remove items, I did and then fasten them down through the floor, enlarging the hole where the screw passed through. On those items that I could not or did not remove, I laid the floor up to it leaving about a 1/8 inch which I filled with caulk and painted to match.
Good luck with your project, it is not that difficult but is time consuming.
Greg
Roadtoaster is offline   Reply With Quote
Old 01-20-2008, 06:13 AM   #106
babendawoodz's Avatar
chatham , Massachusetts
Question cushion flooring
I was looking at 'Cushion flooring' while on my search for the perfect floor. This is relatively new flooring , I think, made by quite a few manufacturers, including Armstrong. It looks like a laminate but has a cushion padding that comes in various mm's. It comes in many patterns, faux wood looks,etc. including black and white checks. Has anyone used this type of flooring. It is also used in many sports applications, for basketball courts, running tracks,etc., so it must be pretty durable, depending on the type of cushion floor you choose. Just wondered if it might be a good choice, ya think?
babendawoodz is offline   Reply With Quote
Old 01-20-2008, 03:28 PM   #107
1973 31' Sovereign
Portland , Oregon
Images: 22
Can you provide some Internet links so we can look at what you are describing?
Old 01-21-2008, 09:41 AM   #108
Cushion flooring
Sure thing.
If you go to the Armstrong flooring site(Flooring, Ceiling and Cabinet Products by Armstrong) and click on the 'Cushionstep' link or another good choice is Gerflor(www.gerflor.com)
and go the 'textile backed rolls' link. You can order the rolls in various widths for a seemless application.
Old 02-10-2008, 03:49 PM   #109
1995 34' Land Yacht LE
Boynton Beach , Florida
Smile Floating Flooring
I have just installed a vinyl floating floor in my 1995 A/S Land Yacht, Cutter LE and it looks great. I used the Traffic Master brand from Home Depot and it was relatively easy to install. All info supplied by Home Depot lead me to believe it would not be a problem in the motor home. However, it does let you feel any variance in the sub floor. I am not worried about that at this time and for the price, about $200, if it needs replaced I can always go back to carpet. Biggest headache was cutting the carpet around everything attached to the floor since I did not gut the unit.
JohnWB is offline   Reply With Quote
Old 02-10-2008, 05:18 PM   #110
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
As for your flooring question... Yes i have seen it at flooring shows. I would see if they will send you a sample of it, it is not that nice of stuff in the hand! As far as instal question.. simple DIY. The non wood grain pattern looks and feels better than wood pattern product..
It looks cheap... but it cost is from mid to high..
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 02-27-2008, 11:05 AM   #111
1966 26' Overlander
Prosser , Washington
Best Price Anywhere
Searched high and low and found these guys. They have a store in Spokane, WA.
Best prices by far and very good quality.
Lumber Liquidators: Hardwood Flooring for Less!
NWOverlander is offline   Reply With Quote
Old 03-01-2008, 05:29 PM   #112
I bought a bunch of inexpensive laminate from them about 5 years ago for my entryway hallway, and it's held up quite well. It was less than $1/sqft, and a glueless click-in system. It was also very lightweight compared to other laminates and wood floors, so it's probably pretty good for a trailer application.
Flooring ideas ALANSD Floor Finishes 47 02-25-2012 02:20 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-06-2006 12:00 AM
Great Flooring Price melprice Floor Finishes 0 07-08-2002 09:48 PM
Replacing the flooring - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 2 06-10-2002 08:59 AM
Removing old flooring and enhancing exisiting floor? Andy R Floor Finishes 4 05-18-2002 01:56 PM
