Old 05-30-2002, 03:19 PM   #1
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
Grades of vinyl...
I was wondering what any of you all know about the diffrent grades of vinyl?
I plan on covering the entire floor of my trailer with brand new vinyl. Once the cabinets are back in, I will install Pergo in the walk ways. It will float on top of the fresh vinyl. So the vinyl will actually not get any wear from foot traffic.
I have priced vinyl at Home Depot & Lowes. Prices range from $6.50/Sq. Yard - $16.00/Sq. Yard. I am looking for a very subtle white pattern that is available in most of the different grades. I would like the floors to stay nice for quite a while so the next owners will not have to think about them. Is the cheaper stuff ok, since it will only be under the cabinets anyway?
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 05-30-2002, 05:52 PM   #2
66TradeWind's Avatar
Images: 22
vinyls
Hi Andy
The main difference between a cheap and expensive vinyl is the durability of the wear layer and / or the construction.
High end vinyls usually are "inlaid" construction with the pattern made up of vinyl chips of different colors fused together creating a pattern that is backed with paper or PVC. These products tend to be stiff to work with and only available in 6 foot width.
Lower end vinyls are usually rotogravure construction which is a printed pattern covered with a vinyl wear layer of varying thickness depending on quality. These also have a backing and are often available in 6 foot or 12 foot width.
Since traffic is not an issue for you the cheap vinyl should be fine and easy to work with. In essence your vinyl will be acting as a vapor barrier.
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
http://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Old 05-31-2002, 11:47 AM   #3
Since I have some rental properties, vinyl and wear problems is something I know more about than I would like.
It is likely your biggest problem will not be wear, as such, but rather damage from cuts. Even the thickest vinyls cut much more easily than I would like. Of course, you probably are not going to have a tenant with a kitchen chair missing the bottom glide on one leg.
BUT!!!! My flooring contacts tell me there is a new kevlar impregnated sheet flooring that is guaranteed not to cut. One of them put down a large section in his highest traffic area and it does seem to be doing amazingly well. I do not have the brand name(s) available, but could get it if it is important. Lots of patterns, very high price for vinyl, but then you do not need much even for a 34' coach.
Mark
Single sheet vinyl solution? TomW Floor Finishes 19 03-26-2004 07:53 PM
vinyl pealing off cabinet doors ?????? vtjoesmith Cabinets, Counter Tops & Furnishings 0 11-20-2003 08:09 PM
Vinyl clad aluminum aviontt Ribs, Skins & Rivets 1 09-26-2003 08:00 AM
Tile or single piece vinyl? Andy R Floor Finishes 36 05-10-2003 06:56 PM
vinyl wallcovering seniors2 Upholstery, Blinds, Walls & Interior Finishes 2 12-23-2002 08:14 PM
