Pulled the carpet from my 99 Safari 23. Found a 6" square soft spot next to door. I removed the loose stuff down to aluminum and need suggestions on how to patch. I was told Dunhams Rock Hard was a good choice. Suggestions?
I would cut away a square shaped piece from the damaged floor and scab in a new piece of the same size. Rot Doctor works great on soft floors but you've actually pulled away the bad wood. With the aluminum underneath this should be an easy fix.
__________________ Sterling - 1972 Sovereign Intl (RB) Eddie - 2003 Ford Excursion (6.0L PSD) Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2 Airstream Life Contributor WBCCI 4CU #5661/AIR #5661
I have done this fix as Mello Mike described and recommend it. The only thing I would add is after cutting out the really punky wood add some support for the plywood patch with sections of plywood which will extend underneath the existing floor and patch 3-4". Screw these supports in through the original floor then put in the patch and screw that to the supports. Use the rock putty or equivalent ( I have used Bondo) to fill in any gaps. Rot Doctor also sells an epoxy wood filler, but it may not be necessary. Where the Rot Doctor comes in is to nuetralize beginning rot and strengthen the wood. Use it to soak in the surrounding area. There are other penetrating epoxy resins on the market under other names.
Pay no attention to the man behind the curtain- WoZ
Thanks for all the advice. The white you see in the picture is aluminum! It is not the belly pan. I was bit surprised when I chipped away the rotton wood and found it. I don't know at this point how far it extends towards the middle of the trailer.
This just seems unexceptable on such a new unit. I know why it happens just wish it didnt. Sounds like a good solution to patch in a new piece however since its in a traveled path you need to be sure its securely mounted and not able to flex. Movement from the rest of the flooring with shorten its effective life span.
I've used "Rock Hard" for patching large holes in wood walls and it has performed great. Don't know how it will work on an RV which flexes, but I think I would try that before cutting out a larger piece of wood an risking a cut into the aluminum below. Besides this situation (with the aluminum under the floor) is quite different than a simple patch of wood that you would then secure with supports to the bottom of the plywood. Really -why not try the Rock Hard first?
Can you call the technical folks at Airstream and show them the picture. Maybe they have a solution that they have tried? It all started with them, maybe they can help steer us in the right direction.
Decided to go with the Rock Hard then read that it's not waterproof! Not sure if it that's a big deal but the damage was caused by water and maybe something like Bondo would be a better choice.
As a painting contractor I can tell you that Durhams Water Putty is not waterproof--it will deteriorate if it continues to get wet. It is also not a structural material--it is not strong enough to walk on. It is great at repairing rotted spots in trim and such around the house but I wouldn't use it on a floor unless there was decent supporting material beneath and only being used as a leveler.
Bondo is not designed for wood repair either. Bondo cures very hard and rigid (great with metal repair) but wood expands and contracts at a greater rate than metal and the bond between the wood and the Bondo will release at some point. A wet environment will make this happen faster.
My suggestion is to use the wood epoxy, and scab in new, properly attached and supported plywood.
Good luck,
Bill
