Old 07-30-2009, 07:58 PM   #15
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Can you call the technical folks at Airstream and show them the picture. Maybe they have a solution that they have tried? It all started with them, maybe they can help steer us in the right direction.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 08-01-2009, 04:08 PM   #16
Chasmorgan's Avatar
1999 23' Safari
Decided to go with the Rock Hard then read that it's not waterproof! Not sure if it that's a big deal but the damage was caused by water and maybe something like Bondo would be a better choice.
Chasmorgan is offline   Reply With Quote
Old 08-01-2009, 06:56 PM   #17
SteveH's Avatar
Common Sense , Texas
If you use Bondo, they make a version called Kitty Hair, and it's a lot stronger because it has strands of fiberglass in it.
Old 08-01-2009, 07:41 PM   #18
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
As a painting contractor I can tell you that Durhams Water Putty is not waterproof--it will deteriorate if it continues to get wet. It is also not a structural material--it is not strong enough to walk on. It is great at repairing rotted spots in trim and such around the house but I wouldn't use it on a floor unless there was decent supporting material beneath and only being used as a leveler.
Bondo is not designed for wood repair either. Bondo cures very hard and rigid (great with metal repair) but wood expands and contracts at a greater rate than metal and the bond between the wood and the Bondo will release at some point. A wet environment will make this happen faster.
My suggestion is to use the wood epoxy, and scab in new, properly attached and supported plywood.
Good luck,
Bill
Cantrell is offline   Reply With Quote
Old 08-02-2009, 09:12 AM   #19
Chasmorgan's Avatar
1999 23' Safari
What wood epoxy would you suggest? Thanks for your help!
Old 08-02-2009, 11:51 AM   #20
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Our Lowe's home center carries Loctite brand--cost is reasonable and it is fairly easy to use. Should work in your application. I think they also carry Simpsons (strong tie) which is good stuff as well. Read the directions well (some of these epoxies make enough heat during the reaction to burn you, for example).
Bill
Old 08-06-2009, 07:28 AM   #21
Chasmorgan's Avatar
1999 23' Safari
Thanks for the all the advice! To date I've removed all the rotten wood, squared the hole with my Dremel tool with a router bit and Dremel Multi-max tool (like multi master tool but way cheaper). The plywood patch has been cut and shaped. Next move is to epoxy in place with Gorilla epoxy and fill in seams with minwax expoxy wood filler. Next step is to use either Rot Doctor or Minwax to impregnate the surrounding wood. I'm moving a little slow on this last step after reading the warnings on the can! Thanks again!
Old 08-07-2009, 06:18 PM   #22
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Do you have pictures of your work?I will be doing the same fix soon.
Gypsy Jo is offline   Reply With Quote
Old 08-08-2009, 10:05 AM   #23
1963 19' Globetrotter
Moline , Illinois
For that type of repair I would suggest products avialable from either West Systems ( epoxy products for marine uses) or a company called Abatron (industrial and architectural restoration products). I have used a lot of Abatron products in my work and they are excellent. These products cost a lot more than the home store stuff but you get what you pay for.
63air is offline   Reply With Quote
Old 08-08-2009, 06:39 PM   #24
Chasmorgan's Avatar
1999 23' Safari
I should be done later this weekend and will post pictures early in the week. I've used Minwax wood hardener and Minwax epoxy wood filler. Both seem to work well.
Old 08-11-2009, 04:03 PM   #25
Chasmorgan's Avatar
1999 23' Safari
Well it's not pretty but I think solid. Squared the hole then scarfed in a piece of plywood with Gorilla Glue epoxy. Had one thru bolt to help set the patch. Filled the edges with Minwax epoxy wood filler. Dark wood is from Minwax Wood Hardner. Remove all carpet and did not find additional areas of rot. Re caulked the offending window and all the others. Now set to replace flooring!
Name:	1999 Airstream 071.jpg
Old 08-11-2009, 05:26 PM   #26
moderator
Airslide's Avatar
Wilton , California
Images: 50
Nice job! I bet it holds up just fine. If you go with somekind of Pergo type flooring it will help distibute around the weight to be even easier on it.. I would make sure that if you use that type of planking that you dont seam it together right over the repair. But in reality its probably stronger than any other part of the flooring...
Thanks for the pictures.
Vinnie
Old 08-12-2009, 08:43 AM   #27
Gypsy Jo's Avatar
1977 28' Argosy 28
Thanks for the pic. Do you have any before the patch went in?I was interested in seeing how you made the hole for it to go in.
Old 08-12-2009, 09:19 AM   #28
Chasmorgan's Avatar
1999 23' Safari
Sorry, I did not take a picture of the patch prior to the wood filler application. I used a Dremel Multi Max tool to square the hole to 6"x6". Then inserted the piece of plywood for the patch. Glued it down with a two part epoxy by Gorilla glue. Seems solid now!
Frame Rot monocoque Repairing/Replacing Floor &/or Frame 328 12-10-2008 10:54 AM
door rot rvtogo Doors & Locks 2 08-08-2008 03:03 PM
Rot Dr. Mariner Repairing/Replacing Floor &/or Frame 5 04-15-2004 08:25 PM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
I have some rot ipso_facto Repairing/Replacing Floor &/or Frame 4 11-07-2003 06:23 PM
