Old 07-03-2008, 07:21 AM   #1
2000 25' Safari
Casa Grande , Arizona
Glued Down Laminate vs. Floating
I read several articles on laminate flooring - everyone seems to be using the floating floor method. Is there any good reason besides being totally permanent not to glue down the laminate? I know it will void the warranty just wondering if anyone has successfully used laminate and glued it down and with what type of glue.
TheHicks is offline   Reply With Quote
Old 07-03-2008, 07:42 AM   #2
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hello.... Float the floor .... we are doing our 2nd Argosy and will not glue it down... The floating floor stood up very well in our last Argosy and we like it so much we are using the same one
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 07-03-2008, 07:46 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
"Totally Permanent" that is the reason not to. The trailer flexes much too much to support a rigid system. I am sure you have seen trailers that had tile glued down and how it pops up over time. Floating is easy to install, easy to remove, and a lot more forgiving to the road.
2004 Excursion 4x4
Old 07-03-2008, 08:55 AM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
They call it a floating floor for a reason. You DO NOT want to glue it down. It needs room at the edges and all over and should not be affixed to any sub-floor so it can float (expand and contract).
Check out this thread...
http://www.airforums.com/forums/f461...ter-41785.html
Lots of good information there on flooring and istallation.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-04-2008, 07:48 AM   #5
2000 25' Safari
Thanks to all who have answered so far - can't find anyone who has glued the floor down and responded but several who floated it. We are planning to float it thanks to the information we have received. I had looked all around the internet and the best info was here at Airstream.
Old 07-04-2008, 12:05 PM   #6
Central , Mississippi
We glued one down in our old RV and never had any issues although I was much tougher to install. I figure the hardwood will flex just about as good as the plywood subfloor so if for some reason I decided to glue another, I'd go for it.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-12-2008, 07:18 AM   #7
1972 27' Overlander
Concord , North Carolina
There is no flex in the laminate itself and it will pop up off the subfloor sooner or later. By floating it you will elimante that problem. The only other issue you will face is cutting the trim and the you will have to (glue) and or find some other way to attach it to the walls to hide the quater inch you need to float the floor. By the way laminate is not a hardwood but a composite and it does not flex at all. If you haven't bought yet you may want to look at cork as an option. You can glue it down as it will flex and looks great and a lot easeir to cut.
solitairenc is offline   Reply With Quote
Old 08-28-2008, 10:10 PM   #8
flint , Michigan
For the simply reason of easier installation, choose floating of glued in my opinion.
Get the best flooring info, advice, and support at FindAnyFloor.com
Find basic and advanced Installation Guides here for almost any type of flooring
floorsRmyhob is offline   Reply With Quote
Old 09-01-2008, 12:03 PM   #9
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I have tile in my Race Trailer. I am constantly dealing with it popping up. I personally hate it.
mustang is offline   Reply With Quote
Old 09-01-2008, 12:04 PM   #10
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
So floating cam also be removed and reinstalled say I had to get to the frame from above then right?
Old 09-01-2008, 01:38 PM   #11
1972 27' Overlander
glued or not
It won't last because the laminate doesn't flex and the floor will.
Old 09-01-2008, 01:49 PM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It would be easier, but some floating floors have the joints glued.
My 73 had parquet floors which were glued in. They seemed to do fine.
Depending on where you live the wide temperature variations in storing a trailer is not usually an application for which residential flooring is designed for, and may also be an installation factor. At least that's what,one manufacturer told me.
Old 09-01-2008, 04:21 PM   #13
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Floating Floors
All laminate floors must "float". You do not glue it to the sub floor and you leave a 1/4" space from the wall all around the perimeter. This is to allow for EXPANSION and contraction.
SmokelessJoe is offline   Reply With Quote
Old 09-01-2008, 09:05 PM   #14
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
It seems when useing a floating floor the wood floor in the airstream would be fine for a subfloor. Just leave 1/4 inch around perimiter for expansion ect right?
screwing through floating laminate DasAir Floor Finishes 6 04-07-2008 07:02 PM
Engineered floating Quick Click Flooring? glacierrunne Repairing/Replacing Floor &/or Frame 1 12-29-2006 06:50 AM
Floating Floor/Laminate Question soldiermedic Repairing/Replacing Floor &/or Frame 44 11-05-2006 05:58 PM
Replacing Interior over floating floor Whipsas270 Repairing/Replacing Floor &/or Frame 8 09-22-2006 10:23 AM
Cork Floating Floor ClassicRides Repairing/Replacing Floor &/or Frame 21 12-01-2005 08:12 PM
