Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 05-08-2015, 04:27 AM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Glue or not to glue
I would like to replace the front carpet in my 2011 30' Classic with the same roll vinyl that she came with. Beau Flor was nice enough to send me samples of their current available patterns since the original has been discontinued. I will go aft until the natural break at the dinette and the counter. Then a trim piece to separate the new from the existing. My question is : was the original vinyl glued down? Should I plan on gluing the new vinyl to the sub floor?
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 05-21-2015, 11:36 AM   #2
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
OK, as a follow up to the lack of responses to my previous posting I decided to order the roll vinyl from Beau Flor that most closely matched the original (which I find very acceptable, more so than the vinyl that ws used by AS in the past). I recieved it yesterday and will start the project next week. What I will be doing is removing the carpet and the vinyl back to where I have the tape measure in the attachment. I will then replace it with the new Beau Flor. and use a molding to separate the new from the original. Hopefully I'll be able to avoid using adhesive. From what I can tell, the original is not glued down. I'll follow up on he results. Opinions??
>>ron<<
Name:	Airstream Classic carpet (1).JPG
ID:	238912   Click image for larger version
Name:	Airstream Classic carpet (2).JPG
Old 05-21-2015, 11:56 AM   #3
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
My 2008 Classic floor is buckling due to temperature extremes. I am considering BeauFlor since they provide flooring to the RV industry.
I checked the Beauflor website. From what I can see it's glued down. I've seen videos of conventional trailer manufacturing and they glue the flooring down prior to cabinets being mounted.
Post photos of you completed project.
Thanks for sharing.
Kelvin
So Airstream is using Beauflor now with the newer trailers?
Old 05-21-2015, 01:23 PM   #4
2004 28' Classic
austin , Texas
I will be following your progress with interest..but have no idea whether to glue or not. What about contacting Beau Flor for info?
Ntex is offline   Reply With Quote
Old 05-21-2015, 02:15 PM   #5
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Can you mention the style or collection and color of Beauflor. Looks like something I could use in my Classic when I get around to this job. Also, where did you order it from?
Kelvin
Old 05-22-2015, 07:59 AM   #6
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Hey Guys,
AS far as gluing down: I will decide when I remove the existing Beau Flor to glue or not depending on the previous set up. My 2011 Classic came with a Beau Flor color that has been discontinued. The people @ Beau Flor were really great in that they sent me samples of all the existing patterns for me to chose from. The closest and the one that complements my existing is Pearwood 14 M. I ordered from the Syntec warehouse in Indiana. 1800 526 8428 Ext 8370 and gave my order to Diane. The vinyl comes in 8' widths which is really great because there is no waste. It took me quite a while to search down the manufacturer and the source. I hope that my info can help others.
>>ron<<
Old 05-22-2015, 08:11 AM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Good luck! I think Gluing will force the flooring to flex at the glue points. let us know!
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-27-2015, 04:56 AM   #8
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Lounge floor finished
Finished the removal of the lounge carpet and original vinyl flooring from the lounge and replacement with full coverage of the entire lounge area with new Beau Flor. The original was not glued down. This made removal and replacement much easier. I am quite pleased with the finished product.
>>ron<<
ID:	239353   Click image for larger version
Name:	Airstream lounge new floor (1).JPG
Name:	Airstream lounge new floor (4).JPG
ID:	239355   Click image for larger version
Name:	Airstream lounge new floor (14).JPG
Old 05-27-2015, 09:52 AM   #9
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Hi Ron,
Did you end up gluing the new floor down, or just the edges. Did you remove the sofa and other cabinets and put the floor down under those items? If you glued did you use a BeaFlor adhesive?
Was that the lightest color Syntec offered? Do you have the collection name and part number?
Thanks for sharing.
Kelvin
Old 05-27-2015, 11:34 AM   #10
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
This was the lightest color that matched up with the width of the previous Beu Flor. The color is actually lighter than it appears in the pictures. I did not remove the couch, but I did remove all the other pieces(see att) Check out # 6 above for all the info on ordering. PM me if you need any additional info. Oh yeah, when you remove the under couch drawer be careful to avoid the slide coming apart and all the ball bearings fall on the floor. Don't ask me how I know. In addition, leave enough length for the new material to go under the couch to avoid seeing the carpet, especially in the middle.
>>ron<<
Name:	Airstream lounge new floor (2).JPG
Old 05-27-2015, 11:35 AM   #11
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Oh, I forgot, I did not use adhesive. I installed the same as AS with staples at the edges.
>>ron<<
Old 05-27-2015, 12:58 PM   #12
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Did you staple the floors under the transition strip?
Kelvin
Old 05-28-2015, 04:13 AM   #13
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Kelvin
Yes
>>ron<<
Old 06-14-2015, 08:21 PM   #14
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
Would you be willing to list a price for the beauflor? We want to get rid of the carpet in our trailer.
Can of beans is offline   Reply With Quote
Old 06-14-2015, 09:44 PM   #15
1979 23' Safari
Wayland , New York
Looks great!
Old 06-15-2015, 06:12 AM   #16
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
The piece that I purchased was 8' X 9'. This actually left me some extra. The total cost for the entire project, including shipping was less than $100.
>>ron<<
Glue, and Pulling Tabs not sticking... Keyair Ribs, Skins & Rivets 1 01-24-2012 12:09 PM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 07:08 PM
How do we remove lettering glue from exterior? rhodyrunwv Cleaning, Stripping & Polishing 5 06-13-2004 05:03 AM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
