Old 08-26-2010, 07:57 PM   #1
1976 31' Sovereign
Indianapolis , Indiana
Flooring weight questions!
Hi all - this is my very first post! Been reading tons of posts on here, we just jumped in head first to revamping a 76 sovereign 31', and boy are we in over our heads a bit. We're repairing some floor rot, and then, trying to decide what flooring will work best.
My main concern is weight. We are really wanting to keep the overall weight down, so I thought vinyl sheet would be great but then my dad, who is helping us, said the subfloor screws and joints would "bleed through" so we would have to put down another thin sheet of plywood to have a flat surface for the vinyl. At that point, aren't we looking at just as much weight as putting in laminate planks? This flooring will go in the entire trailer so that's a lot of weight to add in.
I've read that cork is a good option but it's just not in our budget. The vinyl I had picked out really looked just like laminate "wood" so I was happy with it. What should we do?
Thanks so much!
Sadie08 is offline   Reply With Quote
Old 08-26-2010, 08:47 PM   #2
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Welcome to the Forum.
You're correct. A thin sheet of lauan ply is just added weight. Bleed through shouldn’t be a problem if the heads of the fasteners are tight, recessed or flush, and sealed with epoxy, paint or poly. I’ve used all three and don’t see any difference. As long as the seams in the subfloor are level you’re good to go.
Sheet vinyl is a good medium if you’ve got an empty shell and are looking to cover the floor wall to wall. It’s a pain if you’re trying to cut and fit around existing furnishings in such a small space.
The latest project has a floor that was covered with porch paint by the previous owner. I went with the vinyl planks and it looks great. After the floor was scrubbed and dried the self-stick planks went down easy.
I didn’t go all the way under the new benches or old cabinetry to save both the weight and cost.
Don’t be afraid to jump in. We’re here to help. Here’s before and after shots for inspiration.
Good luck with you trailer. Let us know how it comes out.
Tom.
Name:	Interior On Day of Pickup.jpg
ID:	109446   Click image for larger version
Name:	Nearly Done Dinette.jpg
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 08-27-2010, 02:32 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Sadie08 View Post
... just jumped in head first to revamping a 76 sovereign 31', and boy are we in over our heads a bit. We're repairing some floor rot, and then, trying to decide what flooring will work best.
My main concern is weight. We are really wanting to keep the overall weight down, so I thought vinyl sheet would be great but then my dad, who is helping us, said the subfloor screws and joints would "bleed through" so we would have to put down another thin sheet of plywood to have a flat surface for the vinyl....
Listen to your dad - sounds as if he knows what he is talking about.
THe '78 31'er had 1/2" original plywood flooring. The seams and elevator bolt heads would have been verrry noticable under most any flooring.
I installed 1/4" (finished one side) plywood as a levelling coat - ground/sanded down the seams/bolts prior to using a levelling calk. Make sure you don't put the seams directly over the existing plywood seams - they need to be staggered. I glued down the 1/2" in addition to 5 spotting/countersinking wood screws on about an 8" pattern.
Finished it all off with a 6" X 6" period correct wood parquet....have not had to touch up anything yet, though I did spend a goodly amount of time installing moulding and quarter round to finish the edges (not shown in the pics below).
Check out the square footage of floor actually needing a facelift - not really that much area. No need to make it pretty under the gaucho, beds, or cabinets.
Welcome to the Forum - learn to use the "search" function - it will son become your best friend. Most every possible problem has probably already been documented here - no sense in reinventing the wheel.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-30-2010, 11:54 AM   #4
1971 21' Globetrotter
antigua guatemala , sacatepequez
hi sadie -- i recoomend RUBBER flooring,, tiles or sheet. 500% better than vinyl. i am doing my 4th trailer remodel - it´s the best !! i get mine from PRF ACTIVA - it´s
the non-automotive branch of PIRELLI - they´ve been making flooring for over 80 years. laminate can chip, stain, warp, weighs a lot: rubber is natural, flexible, resilient, insulates well and a treat to walk on. the PRF warehouse always has a great
selection of colours, surfaces ( smooth, raised dot, hammered, slate ) and it comes in
tiles - 20 in. squares, 40 inch squares, or sheet - 5´ or 6´ wide. AND, best of all, they have a close out, discontinued overstock department -- at about $1.50 sq.ft.
lafuente is offline   Reply With Quote
Old 08-30-2010, 01:33 PM   #5
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
$ or?
short on bucks/time/knowledge on what to do? I vote you paint the floor. Go next door (both sides) and across the street-ask if they have any "old" paint they'd donate-then mix them (assuming all latex) and you have a low cost method that can always be changed, especially if you decide on a complete monte later on. The paint will be light weight as well, and you can put it on with just about anything. sometimes "nothing" is the best answer....
ol' bill
wmarsha is offline   Reply With Quote
Old 09-26-2010, 11:01 PM   #6
bothell , Washington
Cork Vs. Bamboo Flooring...
Not sure if anyone is curious or if this is old news or not, but I just did some math on flooring...
(Price and weight from Home Depot website.)
Cork:
$5.33/sqf
1.6lbs/sqf
200 sqf = $1066 and 320 lbs.
Bamboo:
$1.99/sqf
2.03lbs/sqf
200 sqf = $398 and 406 lbs.
Is 100 lbs. worth $668?
mary-sews is offline   Reply With Quote
Old 09-27-2010, 10:40 AM   #7
Rubber flooring costs less and weighs less
$ 1.90 / sq.ft
.93 lb. / sq.ft
200 sq.ft $380 and 186 !! lbs.
and with rubber you don´t have to leave expansion gap or EVER worry about water
leakage, seams opening or bottom rot. ups charges apply from new jersey.
Old 09-27-2010, 10:45 AM   #8
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Home Depot has pergo type flooring that was $4.75 on sale for .59,
yes .59
you need 110 square with waste on that rig
'77 Sovereign Intl 31' CB
Old 10-17-2010, 12:08 PM   #9
RBC
fort Collins , Colorado
floor
Just starting to remodel my AS as well. I have pulled out all of the interior and have just the plywood for flooring now. I plan on filling any holes with auto bonding and then sanding the floor to get it level and clean. I want to put a 6mm poly sheet water barrier and then a floating plank marmoleum floor coving the whole trailer. My question at this point is, how do you know put back everything without screwing them into the floor and then preventing the floor from being a "floating floor". I have looked at cork, rubber and decided to go with the plank marmoleum.
RBC is offline   Reply With Quote
Old 10-19-2010, 06:25 PM   #10
hey rbc - that´s why ´floating floors´ are installed in stationary structures & not in
trailers. there´s no point and all disadvantage. you could put all cabinetry back & lay
the planks in the émpty´space. remember to raise the cabinets etc to compensate for the raised height of the laminate ( doors need to open fully ). i lived & travelled many miles in an rv with a laminate floor & don´t recommend it. why not sheet marmoleum ?
Old 10-19-2010, 07:46 PM   #11
Dag68's Avatar
1965 22' Safari
Shelter Island , New York
Images: 20
Keep it floating by allowing a 3/4 inch space around any screws.
Come on a (1965) Safari with me!
Dag68 is offline   Reply With Quote
Old 10-20-2010, 04:34 PM   #12
RBC
Thanks that is a great idea. I can put floating Marmoleum floors in the trailer all around and just make sure wherever I need to screw into the floor i give it space to float!!!.
love it
thanks
Old 10-20-2010, 05:41 PM   #13
SpaceEgg's Avatar
1959 24' Tradewind
The Grass Capital of the World , Oregon
floating floor and marmoleum
We used Home Depot's vinyl flooring (Allure Light Bamboo). $1.99/sqft not on sale. We installed everything with a utility knife and a tape measure. Elegant simplicity. We desired a waterproof medium (Pacific NW), so we used the vinyl flooring which adheres to itself with a glued strip. After sealing the gaps between floating floor and walls, we have a killing-room worthy waterproof floor. The dirt sweeps off and the water wipes clean. We just screwed right through the floating vinyl to the subfloor when necessary, caulking the screw hole to keep it water tight.
We used marmoleum for the countertops in the bathroom (installed) and the kitchen (pending). Also only required utility knife and tape measure. You can find beautiful colors and patterns. Also planet-friendly. Very happy with both mediums.
ID:	113637   Click image for larger version
ID:	113639   Click image for larger version
SpaceEgg is offline   Reply With Quote
Old 10-20-2010, 07:59 PM   #14
1968 20' Globetrotter
Kelowna , British Columbia
Lafuente...thanks for the tip on rubber! Looks like a good option.
Canlib is offline   Reply With Quote
Weight Limit Questions gerry777 Member Introductions 3 05-04-2009 07:05 AM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
Weight Distribution Questions JimGolden Hitches, Couplers & Balls 19 01-05-2007 12:54 PM
27' B tank layout and weight reduction questions pneum0 2002 Safari 12 09-13-2004 12:33 PM
