Old 10-04-2008, 08:39 PM   #1
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
Question flooring trim?
All right got all my carpet riped out today and plan on putting in a floating wood floor in tomorrow. from some of the people that i have talked to that install this type of flooring they say you need a 1/2inch space from the wall and cabinets so there's plenty of room for swelling and movement.
I was wondering if anyone out there that has done this before would have any suggestions on trim for around the outer edges near the walls.
and i lucked out and the floor in my bathroom had No floor rot in the bathroom.
osolow is offline   Reply With Quote
Old 10-04-2008, 09:02 PM   #2
Images: 59
First, You might want to use 1/2" if the span is greater than 10 ft. If it's less, like across the width of the trailer, I think 1/4" would be enough.
I used trim from Brunner Enterprises. It's 13/16" on the floor side, and 5/8" on the wall. It looks great.
Old 10-04-2008, 10:07 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I am in the process of putting it in right now.... I am leaving about 3/16 of a gap except right buy the door where is it tight but the other side is about 1/4 inch.. I'm putting mine across the trailer.... Not worried about expansion to much as it is not real wood... Plus mine has the foam backing connected to the flooring so it doesn't like to slide on the plywood..
Except in the front of the trailer all the edges will be behind cabinets.. Just gonna cut some maple on the table saw for edging.. Hope to get it finished tomorrow.. will post pics....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-05-2008, 06:08 AM   #4
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
Make sure you attach the trim to the wall/cabinet etc. The floor moves a bit and will easily destroy any joinery if attached to the floor itself..........Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 10-05-2008, 09:58 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
3/16 is adequate. I used extruded aluminum angle for trim. Easy, cheap, and available at local hardware.
Which Flooring???? AndyPenny Floor Finishes 29 09-18-2008 03:26 PM
Flooring arjo Repairing/Replacing Floor &/or Frame 19 04-28-2008 05:57 AM
need new flooring ? bigghpappa4 Floor Finishes 3 08-11-2006 10:41 PM
Flooring Fun-Lovin Floor Finishes 8 09-09-2003 11:15 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
