Old 05-09-2004, 01:48 PM   #15
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Jim,
I don't have them in my 345. I've removed the carpet and didn't see anything.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 05-09-2004, 06:04 PM   #16
Jim Tyrney's Avatar
Steven,
Thanks for the input. I have almost beat a place in the carpet looking for those cutouts!!!!! I was going by the sales phamplet that was with the paperwork that PO's had. I guess Airstream strikes again. Seems like would be a good addition though. Thanks again. Jim
"Property doesn't have rights, people have rights to property"
Jim Tyrney is offline   Reply With Quote
Old 05-09-2004, 08:48 PM   #17
RivetAddict
swebster's Avatar
We're planning something like this when we convert the rear bedroom into a U-Lounge. We'll need a removable table that we can use between the cushions to transition the lounge back into a bed. I've seen this done on tour buses and it works great. They are certainy one of the cheaper things RV related that one can buy!
Steven Webster
AIR 1760
Old 05-13-2004, 06:54 AM   #18
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Cork install update--humidity is killing the project for now, daily T Storms here. I cut most of the pieces using templates from heavy brown paper, they seem to fit and look great, but manufaturer says not to install and seal with humiidity as high as it is now. I am patiently waiting!!
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-13-2004, 09:46 AM   #19
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Cork floor
Where did you get the cork flooring. I just tore out the carpet and padding in my '34 trailer last night to the hallway. I want cork, but am looking for a source. Thanks,
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 05-13-2004, 10:24 AM   #20
Send a message via Yahoo to silver suz
Environmentalhomecenter.com has LOTS of interesting info. Even Lowe's is carrying cork rolls and tiles. I'll send these two and then find the other sources. silver suz
silver suz is offline   Reply With Quote
Old 05-13-2004, 10:32 AM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I tried Lowe's they said they didn't cary it...unless they changed their minds. Try IFLOOR.COM or DIY.COM both have good prices on cork. I bought mine thru a private vendor who had an extra case of 100 sq feet. All I needed was 60.
AIR #005
retired!
Old 05-13-2004, 10:39 AM   #22
Sorry- our lowe's or home depot does. I suggest you use extra tiles as drawer and cabinet liners, under the sink and ref, around the ref, all the closets, under the beds. Cork is an excellent accoustical absorber and insulator. I'm sure you will find places for all your left over cork!!! silver suz
Old 05-15-2004, 05:17 PM   #23
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
well I guess your HD is more liberally stocked then the 5 near my home. My cork is glued and has the first covering of urethane on it. i ran into a few snags...two or three tiles wanted to pop back up after a few days of being glued down, and only part of them popped up, so i had to gingerly pull the edge up and shoot some glue under. The other issue is the battery box door which is in the floor just inside the entry door, it has about 3/4' or more gap between where the subfloor ends and the cover starts. I might have to add some wood in there to hold up the end of the cork flooring. Looks good for an amateur flooring guy though- pictures soon.
AIR #005
retired!
Old 05-23-2004, 04:17 PM   #24
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
After using 3/4" plywood as eding around the battery box for support the cork is about done. I did three coats of polyurethane sealant, with sanding between coats, yet it still could stand one more, as I see a few spots needing it. I did seal around the edges where it now meets the oak trim I put in.
My only problem is an air bubble that has pushed up...about 3 inches long and an inch wide mid-floor. I am considering cutting it out and tacking a new piece in there. The glue did not hold in that spot and I tried shooting some extra glue under the tile, but still got a small bubble.
I have two round plugs almost ready for the table support holes, but I am waiting for magnets to use to pull these plugs out once installed, they used to be easily pulled when carpeted.
Other than that I am ready for the threshold to the bedroom area.
AIR #005
retired!
Old 07-08-2004, 01:09 PM   #25
jpurdy's Avatar
1981 28' Airstream 280
Griffin , Georgia
Just found the pictures and the floor looks great!!
how well does it work on reducing noise while traveling ?????
Enjoy the unexpected
1981 Excella 28' MH
jpurdy is offline   Reply With Quote
Old 07-08-2004, 03:17 PM   #26
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks- it looks good, but I think still needs a glossy coat of finish, as the satin shos some streaking. The noise level on the road does seem better, and the floor cleaned up in no time after a few days at the lake. Broom and a damp cloth for the stubborn spots.
I actually have enough cork left to do it all over if I want to double layer.(no way)
AIR #005
retired!
Old 07-09-2004, 02:40 PM   #27
LeeMo's Avatar
Acworth , Georgia
Talking New Shimmer
Excellent job and a very nice enhancement to the MH! I'm anxious to see up close. BTW: How many bottles of wine did you have to drink to get that much cork?
LeeMo
1979 24' Excella Motorhome
LeeMo is offline   Reply With Quote
Old 07-09-2004, 04:24 PM   #28
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
shoot I have a bag full of corks...but they didn't work for flooring!! I actually bought 110 square feet of cork and needed about 50 so I can redo it some day if I drink enough of that wine
AIR #005
retired!
1955 Flying Cloud Flooring Steph Repairing/Replacing Floor &/or Frame 7 12-10-2003 02:20 PM
Flooring Fun-Lovin Floor Finishes 8 09-09-2003 11:15 AM
Great Flooring Price melprice Floor Finishes 0 07-08-2002 08:48 PM
Replacing the flooring - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 2 06-10-2002 07:59 AM
Removing old flooring and enhancing exisiting floor? Andy R Floor Finishes 4 05-18-2002 12:56 PM
