Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 03-14-2019, 05:05 PM   #1
1995 30' Excella
Harper Woods , Michigan
flooring materials that are suitable by region/season/temps
Hello,
When I knocked off renovation work in October, the exterior caulking & sealing was done, as well as the floor was repaired where needed. I'm happy to report that no leaks were found throughout the winter snow, rain, and extremely cold temps this winter down to -15F (yippee!). Now I'm ready to lay finish flooring.
I had intended to lay carpet squares/puzzle tiles with the idea that they are easy on the feet, insulating, and can be removed for cleaning and subfloor inspection. But I'm still willing to consider alternatives.
After looking through a number of threads about vinyl and laminate flooring, it seems that separations/cracks between planks occur frequently in regions where winter is more severe, and that some types or brands may be more or less resistant to those issues. Is there any consensus about which type or brand is suitable for a given climate?
Bob Blarney is offline   Reply With Quote
Old 03-22-2019, 09:23 PM   #2
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
We used this after removing the carpet in the bedroom we also removed the flooring down to the sub flooring. Click image for larger version
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 04-09-2019, 07:51 PM   #3
Julie-Bob's Avatar
2009 25' FB Classic
What it looks like Click image for larger version
Old 04-09-2019, 10:36 PM   #4
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
Perfect RV floor?
I used the foam-rubber-like interlocking tiles for much the same reason: they were softer and offered more insulation than vinyl or wood, yet easier to keep clean than carpet, and could easily be replaced, etc. They are also very light-weight. Also easy to install. They were also quite inexpensive!
The first set I put in several years ago, however, were very thermally unstable, meaning they would expand and contract quite a bit with the temperature, such that on a hot summer day, they would expand to the point where I had a rolling hills and valley floor, and in very cold weather, gaps between tiles.
But the current batch I put in last summer has not had the same problem. I have not seen any gaps over the winter, and did not see any crazy expansion last summer. So I am very, very happy with this flooring material. I think it's perfect for campers. Here's a link.
https://www.ebay.com/itm/ProSource-P...Z1JaioGce3R_fw
skyguyscott is offline   Reply With Quote
Old 04-10-2019, 06:37 AM   #5
1995 30' Excella
I think your experience is similar to what I've seen. I laid these tiles in my garage and there were no problems. Then my neighbor bought very cheap ones for his garage and had the same thermal expansion/contraction problem as you did. I think that the difference lies in the composition of plastic material.
Julie-Bob: your installation looks very nice. How long ago did you install it?
Old 04-12-2019, 10:10 PM   #6
ScottandMoni's Avatar
1988 29' Argosy
brookdale , California
Hi, thanks for this thread. We are getting ready to put flooring in our airstream. We live in Santa Cruz, CA but will be full-timing in warmer climates, like in AZ all next winder and some tropical zones.
We have done a lot of research on brands that people have issues with. We had planned on going with a Vinyl plank until just now. Today we met with a friend who is a flooring professional and he told us that the chances of the floors expanding in heat and contracting in cold are huge. He also talked about the movement that would happen because we will be traveling. We are pretty bummed.
We googled what comes stock in new airstreams and it seems the flooring is sheet vinyl (YUK!!) We saw some today However, all renovation pics have plank flooring in them.
So, any thoughts on this? We don't want to have to redo and we don't want a buckling floor in our "home."
Thanks ~
Scott and Moni
_______________________
1988 Airstream Argosy 29'
2018 Ram 2500 4X4
Soon to be Full Timers
ScottandMoni is offline   Reply With Quote
Old 04-14-2019, 08:18 AM   #7
1969 18' Caravel
Images: 20
You might want to try the interlocking foam flooring I now have in my trailer. They do not expand and contract noticeably like the first batch I put in. Follow the link in my above post to get the same brand I did. These are available in different colors and textures. I ended up ordering a black set and a gray set and did a nice tile design in my trailer.
Note that the cost to do the whole floor was like $40! So if it doesn't work for you, you are not out much.
I like the light weight, the firm but soft feel, how easy they are to keep clean ( handy in a small trailer where you can track in dirt and such) and modern look.
If you are after a more log cabin look, these wouldn't really do that.
Old 04-14-2019, 08:35 PM   #8
1988 29' Argosy
Mannington Adura Rigid LVF?
Has anyone used or heard reviews of Mannington Adura Rigid LVF?
Scott and Moni
2018 Ram 2500 4X4
Old 01-24-2020, 05:21 PM   #9
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
So, I too was concerned with the thermal expansion etc with vinyl.
I researched all the diff product at lowes and found that only their SmartCore Pro was rated for unheated cabins to sun porches. -25 to 150 per their website. Their other SmartCore Products are not, so beware.
All manufacturers specify a temp range for their products.
To be fair. I used the cheap Traffic Master from Home Depot. The kind that glues to itself and really had no problems for 10 years. It just wore out. So, who knows. Leave big gaps on the edges.
Gkiesel is offline   Reply With Quote
Region 1 Rally 2012- "Streamin the Region" AirHog WBCCI Rallies & Events 45 08-21-2012 12:20 PM
Suitable towing vehicles?? frances s Local Regs & Licensing 5 09-12-2009 04:58 AM
Region 5 and Region 7 VAC Rally overlander64 WBCCI Forum 1 06-22-2007 01:31 PM
Is the 19ft Bambi suitable for 4 people? jcanz Our Community 19 07-16-2003 05:19 PM
