Old 02-20-2012, 02:00 AM   #1
Anchorage , Alaska
Flooring adhesive
Putting new marine plywood sub floor in 1963 Bambi
Plan on sealing the edges and bottom with marine epoxy paint. Not sure what will be used for flooring so want to keep all options open. Some folks have used various means to protect the new plywood from moisture, and some have reported problems gluing down floor later. Wondering if anybody has had trouble with floor adhesives sticking to marine epoxy?
Aktundra is offline   Reply With Quote
Old 02-20-2012, 06:43 AM   #2
reinergirl's Avatar
Hollis , New Hampshire
I think it would be a good idea to choose your flooring before you decide whether to coat the whole floor or not. I know that a forum member said that her marmoleum dealer would not do the sheet goods over a sealed floor.
reinergirl is offline   Reply With Quote
Remove Insulation Adhesive ASNomads Upholstery, Blinds, Walls & Interior Finishes 12 01-05-2018 09:28 PM
When did AS use OSB flooring (Oriented strand board)? Aage General Repair Forum 88 02-07-2015 12:20 PM
Laminate Flooring: which is best? perryg114 Floor Finishes 62 12-04-2012 07:30 AM
Johnsonite Rubber flooring ashe Repairing/Replacing Floor &/or Frame 13 01-24-2012 04:25 AM
New to flooring but making do ….question Stupidnoob Floor Finishes 7 11-21-2011 01:33 PM
