Old 05-09-2011, 02:32 PM   #1
1987 32' Limited
callahan , Florida
Floor prep on chip board flooring.
Would appreciate any suggestions on preparing chip-board flooring in a
'87 AS Limited. The replacement carpet, padding, and hundreds of
staples were removed (mildew odors in the carpet). Also any suggestions
on flooring suitable for north Florida weather.
Airepal
airepal is offline   Reply With Quote
Old 05-09-2011, 02:46 PM   #2
1956 16' Bubble
islworth , middlesex
Hi Airepal
I don't know about North Florida weather but here in the UK I use this stuff, sure you can find a US made alternative. Buffalo Board is Super strength ply board which is not meant to allow water ingress. Paint the cut edges with something to protect it, I use a scandinavian sealent which is water and ice resistant.
This guy made a whole trailer out of it, it's tough as hell and kills saw blades very quickly, be warned
Hope that helps
All the best
Dan
Dan G is offline   Reply With Quote
Old 05-09-2011, 02:48 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Airepal,
By chip board, do you mean OSB (oriented strand board)? There are other products made of compressed wood fiber also. Some Airstreams have used OSB as a subfloor, but I don't know if it were done so long ago as 1987. OSB deteriorates substantially when it gets wet and may need replacement. Some other compressed wood products may or may not be damaged by water. Have you been able to check out the condition of the bottom side of the boards to see if they are good?
If it is ok, then I would paint it with marine quality paint to thoroughly seal it.
There are many threads about subfloors and flooring and I encourage you to search for them and check out the Forums page and look for the subforum under Restoration for floors. You will learn more than you thought you ever would need to know.
Once you figure out what to do about the chip board, you can start thinking about flooring. There are many options including cork, vinyl, carpet, rubber, laminate, solid wood. They all have advantages and disadvantages. Weight is an issue as well as whether they are easily damaged by water.
And welcome.
Gene
Water heater needs new circuit board. Boondocker Water Heaters, Filters & Pumps 0 04-30-2011 08:07 AM
Cork Tile Peel and Stick Flooring lubbockgolf Interior Restoration Forum 4 04-14-2011 11:50 PM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
Bamboo Flooring Argosy22 Interior Restoration Forum 1 01-23-2011 08:41 PM
