Old 12-21-2010, 07:30 PM   #1
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Floor Newbie - Tile floor
I'm really digging this type of floor. When I was in the Navy the ships all had tile floors like this. I even laid some as "extra duty" (another story).. but it went like.. 1) Put tile on tile heater to soften it up 2) Spread black goop on floor 3) place tile on black goop 4) Press to seal.
These floors, if stripped, mopped, and waxed regularly will shine up like mirrors and they can take a real beating.
What is this type of tile called? Is this the way that it is laid?
DanielB is offline   Reply With Quote
Old 12-21-2010, 07:32 PM   #2
cameront120's Avatar
1972 25' Tradewind
Most likely linoleum. The most common brand is Marmoleum by Forbo and comes in sheets or tiles.
North Vancouver, BC
Old 12-21-2010, 07:34 PM   #3
1972 25' Tradewind
Another option would be a vinyl composite tile by Amtico. Not as nice, but very durable. It is often used in industrial and institutional applications.
North Vancouver, BC
Old 12-21-2010, 07:35 PM   #4
Images: 59
I think you're looking at VCT, vinyl composition tile. It's about 1/8" thick and is used in commercial installations.
VCT is a general description, not a brand name.
Old 12-21-2010, 07:48 PM   #5
DanielB's Avatar
Thanks. That looks like it.. VCT.
Old 12-21-2010, 08:03 PM   #6
1968 20' Globetrotter
fair oaks , California
I'm using a commercial grade of vinyl tile made by armstrong. Lots of colors to choose from. Its carried at Lowes and not too expensive. Thats the next phase of my project so I can't comment on installation.
dmcinfo is offline   Reply With Quote
Old 12-21-2010, 08:38 PM   #7
1972 25' Tradewind
If you go with tile, be sure to line up the seams with the joints in the plywood floor to avoid stress cracking in the vinyl tiles.
North Vancouver, BC
Old 01-16-2011, 01:42 PM   #8
What are the ramifications of putting down new vinyl tile over old vinyl tile? Anyone try this?
Old 01-16-2011, 02:49 PM   #9
1972 25' Tradewind
When the original tile is glued securely to the subfloor, new tile is placed over old all the time in home renovations with good results. I've never tried it in a trailer so can't say for certain. My primary concern is that the original tile floor is in good shape - no gaps, large cracks or missing pieces, as those flaws will translate through the new layer of tiles. My other concern would be the additional weight.
North Vancouver, BC
Old 06-14-2011, 03:42 PM   #10
East Greenbush , New York
floor tile asbestos?
hi folks, new here and am wondering if its worth taking up atleast some of the easy to remove tiles because they're asbestos. are they asbestos in a 62 overlander? thanks, joe
Joe K is offline   Reply With Quote
Old 06-14-2011, 04:11 PM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Here are some links on asbestos tile:
Asbestos - Floor Tile Removal - EH: Minnesota Department of Health
Asbestos Tile Removal - Do It Yourself Instructions
There are plenty more websites on this. Armstrong used asbestos until 1980 and I'm sure other companies did, so it is likely you do have asbestos tile. I removed tile many years ago not even thinking about asbestos, but wouldn't do it now. I'd make sure the existing tiles are firmly glued and put a new floor on top.
If you look carefully at the photo in the original post, the tile on the left side transfers bumps and other imperfections from the subfloor through the tile. Make sure the subfloor or whatever is below is smooth enough.
Gene
Old 06-14-2011, 08:40 PM   #12
DanielB's Avatar
new floor
I did get the tile floor done.
The only thing that I might do differently is this:
I used Henry tile adhesive from Lowes. It is milky color.
I talked to a guy that was putting down tile at work and he was using this Henry brand black stuff.
I was told that the milky stuff was water based and would loosen if it got wet under there.
He said the black stuff would not.
I had a couple small bumps from something under the tile. I just banged them down with a hammer.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
Old 06-14-2011, 09:06 PM   #13
Splitrock's Avatar
Sioux Falls , South Dakota
I think you may have found your contacts.
Old 06-14-2011, 10:02 PM   #14
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Tiles and. .
I like the stripper poles. There is a party waiting to happen in there! You going to wrap those in aluminum or have them chromed?
ddstech is offline   Reply With Quote
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 20 09-10-2012 11:32 PM
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Tile the floor first, or last? DanielB General Interior Topics 6 03-28-2011 07:06 PM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
How to attaching the floor DanielB Repairing/Replacing Floor &/or Frame 17 01-09-2011 07:21 PM
