Old 07-29-2010, 05:00 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
'Floating' sheet vinyl?
I am wondering if I install sheet vinyl, could I not glue it down but rather just tack it on the edges and then walls, cabinets and furniture will hold it down...good? bad? Someone stated that the vinyl floors in the newer Airstreams were not adhered with glue but just "stapled" along the perimeter.
adwriter73 is offline   Reply With Quote
Old 07-29-2010, 05:12 PM   #2
Ottawa , ON
I don't see why it wouldn't work, there is quite a bit of flex in good-quality roll product. The owner of the store where we often buy flooring claims that the fibreglas-back stuff is much more stable for "outdoor" use.
But I have never done it in a vehicle that would undergo the temperature extremes that it would in our climate...
Old 07-29-2010, 05:35 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Thats' how I installed the solid sheet vinyl in my Trade Wind. The decision was based on the recommendation of a friend who installed solid sheet vinyl in his Overlander 5 years ago by only gluing around the perimeter. He has had no problems in many thousand miles.
Old 07-29-2010, 07:47 PM   #4
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
so no bunching up or kinks? it lays flat? did you put down a vapor barrier?
Old 07-29-2010, 08:34 PM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
There's a no-glue vinyl on the market. Just lay it down and stick the perimeter down with double sticky tape. Some people do glue down doorways.
Gary
Old 07-29-2010, 09:27 PM   #6
_
the vinyl flooring installed on NEW streams (for many years now)...
is only attached at the perimeter with staples, and around CUTOUTs...
like the toilet hole, vents, wheel wells, wiring tunnels and so on...
no vapor barrier is used.
they are also using bubble foil insulation UNDER the subfloor instead of fiberglass batting.
the problem is NOW we are seeing a lot of trailers with water damage UNDER this vinyl...
at least with the crappy old carpet some of the water could evaporate.
what we need is a semi or one way permeable membrane flooring that breaths...
or lots o'little holes in the vinyl and wood...
cheers
2air'
Old 07-30-2010, 10:13 AM   #7
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
cheers
2air'
I wonder what the reason is for installing it this way if there is such a huge risk of water getting trapped underneath. I just don't want to deal with glue and like the idea that I could "easily" pull it up if needed.
Old 07-30-2010, 11:15 AM   #8
_
clearly the ISSUES were not made clear enough.
floating sheet flooring is QUICKER to install
and reduces the chance of SPITS or cracks when the subfloor moves.
which can happen when GLUED DOWN.
it's also easier to change out...
and MIX in sections with carpet as done on many models.
_________
glued or not, water UNDER a solid surface flooring is trapped.
regardless of how it enters...
at the edges or from the underside or simply condensation on the wood...
there is basically no way for US the owners to monitor for wetness.
_________
since YOU are about to install new flooring, the opportunity exists to CONSIDER HOW 2do this.
cheers
2air'
Old 07-30-2010, 12:01 PM   #9
cameront120's Avatar
1972 25' Tradewind
Glue the full perimeter and no vapor can escape. Period. Let the floor float. Tack down a few points if needed and you've at least got the perimeters 'open' to allow for some condensate to escape. A product like Marmoleum, which is a natural linoleum, might have a vapor permeance that would allow some moisture to escape better than a vinyl sheet flooring. An adhesive tile, rather than rolled good, would be vapor permeable by virtue of all the seams around each tile. If the insulation under your trailer is fibrous, like fibreglass batt or mineral slag, then this is pretty much a non-issue, as the moisture will have a place to go. The problem then becomes does the insulation and wood floor have the opportunity to fully dry after becoming damp or wet. This will depend greatly on the climate in which you live and travel. I would think that the best prevention is to keep the area between the floor and belly pan from getting wet in the first place. Not always an easy task. All of these are the same issues we face when constructing buildings.
North Vancouver, BC
Old 07-30-2010, 12:49 PM   #10
2008 27' International CCD FB
Minnetonka , Minnesota
the flooring in my 08 buckles every spring after the shrink and swell for the winter to summer months. The dealer messed with it a couple times. nothing works. This summer i unscrewed the edging and pulled the flooring to the edge and tacked it down with stapes and reapplied the edging to tuck it under. Its not perfect as so staples show and you never get it to lay perfectly everywhere. Ive come to accept it. In summer when it gets used, it lays down mostly. I wish it could be perfect all the time but its not worth losing sleep over anymore. Im nervous about water damage too and keep a vigiliant look out for spills etc. Our toilet sprayer for instance when used would drip occassionally. Or a leaky skylight. Or shower spills. I wipe em up quick. Lately i worry about the puddle that forms on the seam behind the faucet in the bathroom after my kids use it for a while. Drippy hands and such. I try to keep a rag handi and dab it up so it doesnt seep down behind to the floor ultimately. The caulk seam there is small and seems to crack open with trailer movement and use i guess.
Long winded to suggest you do the same as the factory try and have a float with as few cuts or seams that can allow moisture to get in under it. Just my nonprofessional flooring 2 cents.
Randjg1 is offline   Reply With Quote
Old 07-30-2010, 01:57 PM   #11
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
You should roll out the vinyl and let it rest in the RV, flat, for a couple of days before attaching the edge. This will give it time to relax, lay down flat, and match temperature and moisture content with the rest of your A/S.
TX-16
Dave Park is offline   Reply With Quote
Old 08-02-2010, 10:11 AM   #12
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
I decided to go with it. Put down new sheet vinyl I bought off the rack at the local Home Depot. Was a difficult job to do all by myself, but I like the result. Going to let it lay loose for a couple of days, then i will tape and staple the perimeter.
Old 08-02-2010, 11:10 AM   #13
WOW, nice job! looks fantastic!
Old 08-02-2010, 02:22 PM   #14
1972 25' Tradewind
Is that the TrafficMaster strip flooring? If so, be sure to roll the seams. They have a habit of separating otherwise.
North Vancouver, BC
Glued Down Laminate vs. Floating TheHicks Floor Finishes 15 09-01-2008 09:31 PM
screwing through floating laminate DasAir Floor Finishes 6 04-07-2008 07:02 PM
vinyl tile vs. one piece vinyl loki Repairing/Replacing Floor &/or Frame 69 02-18-2007 03:38 PM
Cork Floating Floor ClassicRides Repairing/Replacing Floor &/or Frame 21 12-01-2005 08:12 PM
Single sheet vinyl solution? TomW Floor Finishes 19 03-26-2004 07:53 PM
