Old 12-31-2014, 02:21 PM   #1
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Flexible baseboard molding
Just put in a floating laminated floor, still need to complete all the base board moulding. Looking for ideas, currently thinking about using flexible quarter round. Did a quick search and it appears that there are several companies offer this type of molding. Some of these can be stained and looks like wood.
http://www.amazon.com/Flexible-Mould.../dp/B006R99T0U
Anyone ever use this type of product? Any suggestion?
Larry
larry b is offline   Reply With Quote
Old 12-31-2014, 02:59 PM   #2
dougandlori's Avatar
2004 28' Classic
Fresno , California
I bought this from Amazon for my 95 Excella. If worked fine for me.
Good luck.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 12-31-2014, 03:04 PM   #3
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Good luck.
Thanks colld014,
How did you attach? I was thinking small screws into the wall/cabinets and then using wood putty to cover the screw head.
Did you paint or stain? I would like to stain, just wondering how good this product accepts stain.
Thanks again, Larry
Old 12-31-2014, 05:31 PM   #4
Wayward's Avatar
Cary , North Carolina
I use it remodeling now and then. It is harder to stain-match to hardwood flooring than real wood - even the stuff with faux woodgrain. So I paint it to match the baseboards.
I suggest you try painting it to match your wall color (or whatever the vertical surface is), and see how that looks.
I lightly sand, wipe with acetone, and then prime with Stix.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Baseboard jornvango Interior Restoration Forum 3 10-04-2013 07:32 PM
Baseboard heaters Forger Furnaces, Heaters, Fireplaces & Air Conditioning 6 04-20-2011 07:51 PM
Help! Need recommendations for flexible molding Maryw164 General Interior Topics 2 04-27-2009 01:16 PM
