03-17-2017, 12:15 PM
2012 25' FB Flying Cloud
albany
, Georgia
Finished putting the new floor down.
Here are some images of the floor now down. Love it.
03-17-2017, 01:03 PM
1973 25' Tradewind
Bloomsbury
, New Jersey
floor
looks good, glue down or floating?
03-17-2017, 01:10 PM
albany
, Georgia
Floating, read the previous posts I put out after researching the product.
It looks like a floor should, real.
The molding was the second hardest part. It is 1/4 by 1/4 and bends like string. I searched and searched for something small but plain, cut all the pieces, then glued sections together, then painted with three coats and glued down.
Best Airstream floor I have ever seen so far.
03-17-2017, 02:00 PM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
What molding product is that?
@living.somewhere.yonder | Instagram
03-17-2017, 05:23 PM
albany
, Georgia
It took just under two weeks for them to make it and get it to me. It is the first at the top left of the page and I got the higher priced one. The paint did not distort when I was bending it. And the glue they recommend was Gorilla super glue an instantaneous bond. It has an incredibly strong bond and made the job a lot easier in the end.
https://www.trimster.com/flexcat.asp...nd&option=all#
03-18-2017, 06:23 AM
2014 30' FB FC Bunk
Anywhere
I assume you glued it to the wall and left the floor beneath to float?
03-18-2017, 06:45 AM
1980 25' International
Lorton
, Virginia
Jmpgino, Floor does look good. Did I miss the brand? Who makes the flooring? Job well done.
Rick
03-18-2017, 07:03 AM
2005 30' Safari
Montgomery
He used Smartcore from Lowes. If you're interested in digging (or just can't help it), here's more info he posted about it:
http://www.airforums.com/forums/f461...ing-96470.html
He starts about post #93
03-18-2017, 07:49 AM
albany
, Georgia
Regarding how I put the molding down. I glued it to the floor and only the floor because I decided if the floor had issues then it would easily come up. Also I did not want to touch the cabinets.
Read my earlier posts on the flooring. I did freezer and oven tests on it, it did not expand or contract, twist or warp in any way. And when talking with the manufacturer they agreed an expansion gap was pointless considering the widths I was dealing with inside the Airstream.
03-18-2017, 01:17 PM
1966 28' Ambassador
Mobile
, Alabama
I installed Smartcore flooring in my Avion in October. I have been very pleased with it - no problems with temperature changes or movement. I used the hickory color.
03-18-2017, 11:02 PM
2017 23' Flying Cloud
Parker
Jmpgino, I read your other posts, thanks for sharing. Did you install this over the existing floor or remove the existing floor? Also, did you remove furniture and cabinets to install, or just cut and match around the existing furniture?
Thx
Troutboy
03-18-2017, 11:19 PM
2014 30' FB FC Bunk
Anywhere
Interesting. You cant see any gaps at the walls?
03-19-2017, 08:42 AM
albany
, Georgia
I laid it straight on top of the factory stuff, that stuff is paper thin believe it or not.
Took a lot of scribing, and even some template making.
The round sink and bed ends were easier to deal with after some thought. The bed can be unscrewed from the floor, I was then able to lay a plank under, put the bed down, scribe the cut line, then lei ft up again and remove and cut the plank, easy. Sink was the same but I could only get a paper template for that one.
The transition into the bathroom was not easy, and again scribing got me the accuracy.
The added weight was around 90 lbs.
Next weekends project is adding an electrical heating element into the propane water heater, still thinking about running the wires as there are three options in my mind at the moment. Doing this in a 25 footer is an easy job.
03-19-2017, 01:36 PM
Parker
Well looks awesome, so you scribed like a pro! I'll keep this in mind when I need new floor. Good to know you can lay it on top.
Troutboy
