Old 03-02-2012, 06:26 PM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
filling cracks and bolt indents
What to you recommend for filling gaps and bolt indents in the sub floor to level before linoleum?
Barry
goshawks00 is offline   Reply With Quote
Old 03-02-2012, 06:53 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Some info. for you. You can find premixed compounds at Lowe's, etc.
Self-Adhesive Vinyl Tile Floor Preparation
Old 03-02-2012, 09:02 PM   #3
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Barry,
I used auto body filler, fills and sands easily.
Tim
Beaker63 is offline   Reply With Quote
Old 03-02-2012, 09:12 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I would use Rock Hard wood filler. It is available at Lowes or HD and it is very inexpensive.
Dan
TouringDan is online now   Reply With Quote
Old 03-03-2012, 03:47 PM   #5
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Being an old hotrodder, I have body filler on site and am familiar with it thanks.
Dan thanks also I'll make a trip to Lowes and check out Rock Hard wood filler also before taking a dive into some of the glass fillers available in the garage.
Old 03-09-2012, 03:53 AM   #6
1969 18' Caravel
Jensen Beach , Florida
Magic Trick
I had some left over fiberglass resin so I mixed up some and poured it into the bolt holes, slightly overfilling each one. To my amazment when I came back from the store half and hour later several of the holes were empty. If you have body filler, use it. At least you will only have to repair the holes once. A body file knocks down the excess nicely.
DontBSilly is offline   Reply With Quote
Old 03-09-2012, 05:41 AM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I tried a couple of things. Used floor leveler compound from HD where I put a patch in the floor where the original heater duct was in front of the gauchol It was good for a bigger area but if I was doing it again I would just used auto body filler. The floor leveler is a cement based product and it is hard to sand if you put it down too thick. To cover the heads of the individual bolts that were somewhat sunk into the old floor I used West System Epoxy with microballons filler added to make it about the consistency of peanut butter. The epoxy will have a little more flex that bondo over time but it probably won't matter. Either the epoxy mix or bondo should work fine.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 03-09-2012, 06:06 AM   #8
1981 31' Excella II
New Market , Alabama
On my trailer the only way to get the bolts out is from the top. If you fill the heads up you are going to have to cut them out if you ever have to repair the floor and we know that AIRSTREAM FLOORS NEVER ROT. I would consider something like luan as an underlayment.
Perry
Old 03-09-2012, 08:31 AM   #9
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Ha-Ha, yes they will last for ever, but then again if I need to remove them it another layer (of luan) that would need to be removed!
BTW it's done and all is well. 5/8" 7 ply marine, after two layers of fiberglass on edges and 1' back) screwed from the top with 1/4"-24 self tappers. All seams glassed it afterwards and sanded flush.
Thanks all for the suggestions,
Barry
An airstream video and sound system rodsterinfl Audio, Video & TV 7 08-09-2012 03:23 PM
Gutting, need help w plumbing diagram idaramin Sinks, Showers & Toilets 9 03-04-2012 09:22 AM
16'' wheels and tires upgrade on older Airstream woodfox45 Tires 9 03-03-2012 11:16 PM
NEWBe and still learning this site.. Need new shoes Sodbust Brakes & Brake Controllers 4 03-02-2012 06:18 PM
Name change for me and home/avatar AIR-Quarius Working on the Road 3 03-02-2012 08:02 AM
