Old 07-24-2007, 11:15 PM   #1
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Engineered glue down
so I've read most threads about flooring. We see hardwood (and hardwood look alikes) in lots of trailers. We've been looking at the 5/16" glue down engineered flooring which is supposed to be very stable due to its plywood type construction, enough so for basement floors and unheated spaces. Of course a small expansion joint, but I would think it glued down would help stabalize the floor too, but wondering what experience people have had. Have a clean solid plywood floor at this point.
goransons is offline   Reply With Quote
Old 07-24-2007, 11:25 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
In my humble opinion, bad idea. One of the joys of the Pergo and pergo-like floors is that they are easy to install, easy to remove, and tolerant of water (or so the ads say). I think it would be a big mistake to put down a flooring over the Airstream plywood that was semi-permanent. As vintage afficiando, I wonder how many times the floors in a 30-40-50 year young Airstream has gone from linoleum, to tiles, to carpet, to Pergo? And how many times has a rearrangement of cabinets demanded a new floor?
Make it easy. I don't care if the Pergo is a little loose and might even squeak a little because I put it in a little tight--what I want is current ease of maintenance (carpet, ugh) and the ease of mind that I can take it out and change the color, or orientation, or placement--without tearing the floor apart.
Wait till you have the water flood catastrophe and need to get the floor up just to dry it out...or the new significant other hates the color/orientation.
Zep
Old 07-24-2007, 11:31 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Another consideration is; what happens if you need to pull out the refrigerator. The new floor might be too high to get it out. I could pull my pergo out from that area if I had to.
Richard
Old 07-25-2007, 12:36 AM   #4
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
goransons, what's the weight of the engineered versus pergo? it seems like the engineered is more of a hassle than what it's worth.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 07-25-2007, 10:31 PM   #5
goransons's Avatar
1963 22' Safari
flooring
well the weight is actually less on the samples we looked at, being 5/16 of an inch thick, and a 25 year warranty. We have the entire kitchen out including the fridge,and both couches, so the bathtub and bathroom wall are our only things to cut around (toilet is out too). I've put lots of pergo in, and lots of glue down, I'm not so worried about the effort, but was worried about flex etc in the trailer.
Old 07-27-2007, 12:45 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Wood floors should "float" so they can expand and contract. Gluing or screwing the flooring into the floor won't allow it to do this.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-27-2007, 12:50 PM   #7
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
You hit on the main reason I wouldn't glue it down - Flex. Then there are the other reasons mentioned above.
Dave
Fyrzowt is offline   Reply With Quote
Old 07-27-2007, 02:43 PM   #8
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I have pulled out carpet and put in the floating floor and think it actually weighs less than the carpet.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 08:08 PM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 06:15 PM
Termites Rob Repairing/Replacing Floor &/or Frame 7 10-25-2002 09:56 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 04:05 PM
Blinds ALANSD Upholstery, Blinds, Walls & Interior Finishes 35 04-01-2002 02:54 AM
