Old 11-08-2009, 04:28 PM   #1
dick&claire's Avatar
2011 30' Flying Cloud
North Falmouth , Massachusetts
Engineered Floating Floors
Any one used "click" type engineered flooring in their RV? What was you experience?
Dick and Claire Wiklund
North Falmouth, Massachusetts
"Judgement is based on experience and experience is based on poor judgement"
dick&claire is offline   Reply With Quote
Old 11-08-2009, 04:49 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
3 years alls well.
I left a gap around but because you're not a fixed location I put a dab of silicone every 10-12 inches.
That way it can move but not shift.
I also used Prodex insulation under it instead of the blue foam they recommend
'77 Sovereign Intl 31' CB
Old 11-16-2009, 02:48 PM   #3
Engineered Floor
I'm almost done installing a Bruce engineered floor, click & lock, in prefinished natural oak. It is amazingly easy and looks great. I was afraid that it might slip and slide but it is rock solid in place and I don't think it will move. I will post some pictures when I've finished.
Old 11-16-2009, 03:27 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
This post has my comments after installing new flooring.
http://www.airforums.com/forums/f38/...cho-56547.html
The biggest single thing to consider is the locking mechanism of the flooring and how it will work in the small area of the trailer. Armstrong was my choice.
2004 Excursion 4x4
Old 11-18-2009, 06:13 PM   #5
tinman9's Avatar
2003 34' Classic
1996 28' Excella
Winchester , Tennessee
Is reattaching the couch,dinette,and other items a problem. Screwing thru the floating floor ?
tinman9 is offline   Reply With Quote
Old 11-18-2009, 06:26 PM   #6
HowieE's Avatar
Images: 12
I only carried the flooring a few inches under the leading edge of the coach. No reason to use the extra material all the way to the front of the trailer.
Where the dinette and cabinets attach to the subfloor I set them in place and marked the flooring down through the original holes, removed the cabinets, and then drilled a 1 in. clearance hole through the flooring and screwed down through these holes. This will allow any movement that the flooring may have without it binding on the screw. Now that said I have seen no evidence that any movement has ever taken place.
2004 Excursion 4x4
Old 11-18-2009, 08:21 PM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Installed a "pergo" type floor in the back part and left very little gap since the area is too small for much expansion( 1/2" recommend on a twelve foot run sideways comes out to about 1/8"). Works fine-no problems in three years and some extremes of heat and cold.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 11-19-2009, 05:39 AM   #8
1986 34.5' Airstream 345
Tyler , Texas
Hi! I recently completed the installation of an Armstrong simulated tile flooring in my 345.This floor looks great but was a nightmare to install since it comes in 14x42" pcs. Stay with the smallest width flooring you can find and you should be finePete
pjude is offline   Reply With Quote
Old 11-19-2009, 08:04 AM   #9
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
It will move a bit because of vibration. I used
screws to hold it in position. Easy to clean.
We love it!
kennethowens is offline   Reply With Quote
Old 11-20-2009, 07:26 AM   #10
New Floor
I chose a Bruce Flooring product, 3/8" engineered solid wood, with a top veneer of natural oak. Installation is "press and click", no glue, no staples. It goes on top of a thin layer of foam/plastic. Most of the installation is quick and easy. The devil is in the details, fitting around cabinets, scribing to the walls, trimming the edges (I used 3/4" oak scotia molding), and dealing with the reinstallation of seats and tables. Both the seat and the table required that I fabricate some custom brackets from sheet steel and aluminum, both of which are sturdier than factory supplied. Sheet metal screws were replaced with rivets. Whole project, including making a new dining table, took about a week and probably cost $350.
ID:	91297   Click image for larger version
ID:	91299   Click image for larger version
Glued Down Laminate vs. Floating TheHicks Floor Finishes 15 09-01-2008 09:31 PM
screwing through floating laminate DasAir Floor Finishes 6 04-07-2008 07:02 PM
Engineered glue down goransons Floor Finishes 7 07-27-2007 01:43 PM
Engineered floating Quick Click Flooring? glacierrunne Repairing/Replacing Floor &/or Frame 1 12-29-2006 06:50 AM
Selling Engineered Junk Janets Husband Off Topic Forum 2 05-18-2004 07:17 PM
