Old 07-12-2002, 08:44 AM   #1
melprice's Avatar
End Joints in New Floor
I have just bought some engineered hardwood flooring and I'm going to try and install it this weekend. It doesn't come in single planks like some I've seen, it's has 3 planks pre-glued.
The instructions are unclear about the second row of 3, I assume you wouldn't just lay them next to each other or else the end joints would all be in one line.
I'm thinking I would chop something off the second plank so the seams don't line up. Anyone done this?
Melvin and Sheila
1972 Trade Wind
Cleveland, OH
melprice is offline   Reply With Quote
Old 07-12-2002, 08:51 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Mel,
I have not personally done this but I ahve seen it done on many a DIY show. My reccomendation id to cut one in half. This lets you use both of the pieces and then you will have a running bond (offset) throuout the floor. This will be much stronger that letting the seams line up and will help to prevent buckling and seperation. So full plank, 1/2 plank, full plank, etc. is how I would do it to strart. of course when you get to the other end you will need to cut to fit.
good luck, and post some pics, we would all love to see how it turns out!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-12-2002, 10:47 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Mel ~
I would suggest staggering the joints of whole the sections by alternately starting the first row with a whole section then the second row with a half section, then a whole section at the third row, a half section at the fourth row, etc. I think this is the same as what Brett has already suggested, but a diagram might help, I've attached one below...
Good Luck!
Shari
Old 07-12-2002, 11:16 AM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Thirds
I have seen it done in thirds, also. Full sheet, 1/3, 2/3, full sheet. That way end seams are always separated by at least 2 widths of uncut sheet. That appears to be the way our diningroom is floored.
John W. Irwin
WBCCI #9632
Luan skin for new floor? TomW Floor Finishes 41 04-08-2009 08:19 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
Floor repair:epoxy vs resin TomW Repairing/Replacing Floor &/or Frame 11 12-24-2003 11:32 AM
front suspension/ ball joints wb13798 Mechanics Corner - Engines, Transmission & More... 13 11-07-2003 07:57 AM
