Old 04-10-2007, 05:29 PM   #1
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
Dry Ice to Remove VAT
Until the coffers get refilled I'd like to keep the original '58 9x9 VATile. There are four tiles that need to be replaced at the door. I figure that I can harvest my needs from under the bed but need to find a way to get full tiles up.
Does the Dry Ice trick work? The tiles are pretty darn crispy.
bevman is offline   Reply With Quote
Old 04-10-2007, 05:36 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This worked for me, you should try it on a tile where you can't see it, or a damaged one you are going to replace, before going whole-hog.
I used a clothes iron with steam, to warm and moisten the tile I was pulling. It came up in one piece.
Old 04-10-2007, 06:22 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I don't have tiles as old as yours...but we always went the heat route, just be careful an don't get any of the wood work too hot FWIW we used to pull tiles up off the floors at one place I worked with a propane torch
Aaron
WBCCI #XXXX AIR #2495
Old 04-12-2007, 09:52 AM   #4
bevman's Avatar
Does anyone have success stories about the best way to remove the old, black mastic from the backs of the tiles and from the location to which I want to move the replacements?
Old 04-12-2007, 12:48 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
You sure you want to mess this much with vinyl asbestos tile? Be sure to use a good canister filter mask and some method to hold down dust. I've seen the licensed removers use a lot of water when they're working with it -- not quite what you'd want to do on your Airstream floor.
5 meter Langford Nahanni
Old 04-13-2007, 08:55 AM   #6
bevman's Avatar
Moving four/five tiles is less hazardous that ripping up the whole floor, n'est ce pas?
Noise dry camping ChrisAich 2002 - 2005 International 24 07-28-2003 06:58 AM
Stone Guard/ Keep it or Remove it? 74Tradewind Rock Guards, Segment & Window Protectors 9 06-26-2002 01:09 PM
How to remove the glass from windows? Andy R Windows & Screens 2 06-19-2002 09:30 AM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
