Old 03-16-2010, 11:01 AM   #15
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I found a heavy duty sheet vinyl with cork pattern. Looks like the real thing, it was a lot less expensive. I felt that one piece solid flooring would be easy to clean and help prevent any water from every getting to the flooring in the years to come if leaks develop. (Leaks in an old Airstream- what am I thinking).
Old 03-16-2010, 12:49 PM   #16
Images: 59
Originally Posted by 47WeeWind View Post
Markdoane:
I love the figuring in your cork flooring. Could you please share with us the manufacturer and name, shade, number or particular description of the cork you used? Where did you buy it? Did it come in sheets, trips or square tiles? What finish did you use to bring out the beautiful color? More information please! Thank you.
Thanks. The figuring is even more beautiful in real life. The manufacturer is APC, and the name is Chronus Natural. It's a little way down in their gallery page.
It comes in the 1 ft by 3 ft (nominal) click together planks. It's engineered, so there is cork on the top and bottom, with MDF in between. It's about 7/16" thick. What you get is prefinished with some type of urethane that's pretty durable. It's a floating floor.
You should be able to order it from any floor store, I'm not sure about HD or Lowe's. Cost was around $5 - $6 per square foot. I laid it over new VCT tile.
Old 05-05-2010, 08:48 PM   #17
1966 22' Safari
bellingham , Washington
Can you tell us how to get "cork" type lookin floors or the real thing please???
samaki is offline   Reply With Quote
New Flexsteel Sofa on Cork Flooring? Roadrunner Cabinets, Counter Tops & Furnishings 5 05-02-2010 05:32 PM
Cork flooring question guy99 Repairing/Replacing Floor &/or Frame 19 12-02-2006 03:24 PM
Best Way to Install Cork Flooring? highmark Floor Finishes 9 08-23-2006 08:41 AM
OSB For Cork Looking Flooring topazken Repairing/Replacing Floor &/or Frame 8 10-16-2005 04:38 PM
Cork flooring ALANSD Upholstery, Blinds, Walls & Interior Finishes 5 01-14-2004 07:14 PM
